lt1 turbo?please help
Old Dec 1, 2010 | 10:04 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
Axle/Gears: Ford 9in w/ Strange 3.70s
hey, im swapping my 2,8l v6 to my 1996 5.7l lt1 and im definately thinking about putting a turbo in it, does anyone know 1. will my block handle twin turbos and what type of affordable turbo should i get that can put in boost at semi- low rpms, like start putting in boost around 2500 rpm? thanks
Old Dec 1, 2010 | 10:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: lt1 turbo?please help
depends...how much power and what internals will you have in it? stock bottom end? probably dont want to push much more than 500whp and thats only if rpms are lower and tune is spot on.
Affordable turbo? Master Power comes to mind..about 550-600 each. I ran those on my 401 for about 400 miles before swapping to larger Master Power units. Never had a problem with them but 400 miles is NOT alot
Depending on the power, T3/T4 with small A/R on the turbine side could get boost in around 2500-3000 rpm easily and still make good power up top. May beable to get the .68 T4's in by then as well but probably not until 3500 or so.
Old Dec 1, 2010 | 10:58 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
yes, i plan on keeping the stock block for now, i just want to have a little fun on the street, i have no intention on putting this thing on the track yet, but i read that a 1996 lt1 can handle a great deal of horsepower with work, but ive already bought a ford 9 in rear with 3.70s and a strange centersection, i just wanted to know a trustworthy kit thats affordable and doesnt require me to change my pistons or rods, etc.
Old Dec 2, 2010 | 12:21 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Dont know of any kits for these cars...going to have to fab your own, atleast could possibly start with a purchased set of headers/manifolds from somebody. Few places have something that could work but on a stock motor with LT1's high compression ratio, you wont beable to run much boost on pump gas. I think 10 is all you should try but some may have gone higher.
The only other kits available that could work out but would need abit of fab work to adapt to a 3rd gen are the STS remote mount turbo kits and they are mostly single turbo kits
Old Dec 2, 2010 | 09:58 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You definitely want to keep you boost low if you can I read way to many horror stories from guys with lt1's blowing up their engines though I must admit I question their tuning on a lot of them. I would say 7-8PSI would work nicely and be relatively safe if you have a good tune.
Old Dec 3, 2010 | 04:19 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
theres a girl on the cobalt ss forums running twin t3/t4 50 trims on low boost in a gto an getting 536 hp at the wheels an runninng 11's in colorado ...
Old Dec 3, 2010 | 09:15 PM
SS350scott's Avatar
Car: 1988 camaro
Engine: 350 ci LT1
to tony89gta, i see your 5.7 is supercharged, what type of supercharger are you running and how much boost does it put in, also what other mods do you have done, and is your motor also an lt1
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
bjpotter
Oct 4, 2015 07:48 PM
New2Chevy
Sep 28, 2015 12:35 AM
