tbi nitrous?
Old Dec 2, 2010 | 11:53 AM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
tbi nitrous?
do they make kits who makes them?
Old Dec 2, 2010 | 01:31 PM
joker0907's Avatar
Car: 1991 camaro rs, 2001 buick century
Engine: 305, 3.1
Re: tbi nitrous?
http://www.jegs.com/i/Barry%20Grant/...0002/-1?CT=999
all i did was google nitrous kits for 91 camaro rs....
Old Dec 2, 2010 | 02:55 PM
Ronny's Avatar
Re: tbi nitrous?
I used NOS universal kit...
Old Mar 2, 2011 | 02:04 PM
88chevycamaro's Avatar
Car: 1988,1989 camaro
Engine: sbc 350 TBI
Transmission: 5 speed, th350 w/shift kit
Axle/Gears: 3:27
Re: tbi nitrous?
is that a 305 or 350?...you havent had any problems with it?.....did you have to mod anything to put it on?
Old Mar 2, 2011 | 02:06 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
Re: tbi nitrous?
http://www.hawksthirdgenparts.com/ni...bottlewet.aspx
hawks makes this one but i dont know if thats a direct bolt on system?
Old Mar 2, 2011 | 02:10 PM
Ronny's Avatar
Re: tbi nitrous?
1984 chev vette 350. I placed the nozzle in the TBI bonnet/hat. Drilled and threaded. sealed with Locktite. Fuel line comes from FRP(aftermarket) port. N20 is controlled by my aftermarket ECU. Not very difficult install. Suggested jetting by NOS was very rich on fuel. 50-75 HP jetting. Needed to lean it out quite a bit. Only had on car a month last fall then stored.
Old Mar 2, 2011 | 02:14 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
Re: tbi nitrous?
thanks for the reply...i Might try to put it my car next summer but its completly new to me so im trying to get as much info as i can...do you think the one hawks is selling would do the job?
Old Mar 2, 2011 | 02:37 PM
Ronny's Avatar
Re: tbi nitrous?
I think I paid much less for my NOS sniper on ebay.
Old Mar 2, 2011 | 02:38 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
Re: tbi nitrous?
what did you get in the kit?
Old Mar 2, 2011 | 03:49 PM
Ronny's Avatar
Re: tbi nitrous?
same as the link above. bottle , stainless lines, solenoids 2, relay, arm switch, fittings, assortment of jets(15), trigger switch, brackets. complete. needed nothing.
Old Mar 2, 2011 | 04:00 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: tbi nitrous?
how man degrees did you dial back your timing ?
Old Mar 2, 2011 | 04:11 PM
Ronny's Avatar
Re: tbi nitrous?
3 deg done by ECU only when triggerred. Otherwise I run on non notrous .bin. Knock sensor does another 2. No knock yet.
Old Mar 2, 2011 | 04:15 PM
Engine: sbc 350 TBI
Axle/Gears: 3:27
Re: tbi nitrous?
would a mild cam do it any good??
Old Mar 2, 2011 | 04:35 PM
Ronny's Avatar
Re: tbi nitrous?
see comp cams line of N20 specific cams. Mine is 224/230 @ .05 114 LSA
Old Mar 2, 2011 | 05:28 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: tbi nitrous?
i'm putting in a lt1 cam out of a 96 impala how will that cam work with nitrous ? not high jacking ,if this is a good cam than theres your answer .lol
Old Mar 3, 2011 | 08:57 AM
Ronny's Avatar
Re: tbi nitrous?
<100hp should be OK. IMHO. Over 100 consult comp cams or their website on N20 cams
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
