adjustable fuel pressure regulator
Old Dec 24, 2010 | 11:13 PM
IROC_Champion's Avatar
Car: 1991 z28 Convertable
Engine: Tpi 350
Axle/Gears: 273 built ten bolt posi
i purchased a unknown brand fpr used and the screw is turned out pretty far not sure of the setting my car is pretty stock so all i need really is a little more fuel pressure also i have a modified fuel rail with a pressure gauge any setting suggestions?
Old Dec 25, 2010 | 06:08 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: adjustable fuel pressure regulator
do you have a fuel pressure gauge? is it carbed or fi? if it is stock why do you need more fuel?
Old Jan 11, 2011 | 06:21 PM
Engine: Tpi 350
yea i have a pressure gauge and it has a mild cam and upgraded ignition system so more fuel is needed trying to getit dead on for the fuel and i also have a air fuel ratio meter
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
