whats the best turbo?
I have a 84 z28 camaro and I was wonder what would be the best turbo for the car and how much money it would cost me to buy the engine is a 305 I have a 5 speed tranny and a custome exaust on the care already I also have a corvet carb and air intake that I haven't put on yet idk if that will make any diff in horse power or not?
Re: whats the best turbo?
no you would have to buy a blow through carb for the turbo to work or see if you can send your carb to be built into the propper spec. and a t3/t4 turbo keep your boost no higher than 7 psi on a stock internal motor remember the bigger the turbo the longer the boost lag unless you have a built motor to back it or a shot of nitrox to wake the turbo up...........in your case unless you want to dump a tone of money into that 305, put a 100hp shot of nos !!!!less time, money, pain it the ***
*(Nitrox) 100hp kit $250 to $350 on ebay, two hours install time
*(turbo) 5lbs to 7lbs of boost is about 100hp new $2,500 turbo kit only maybe $1,000 used takes a good mec to install about 3 1/2hrs turbo kit only
motor built to handle big boost (15lbs to 20lbs) $7 to $8 thousand "forged internals, good heads, and the best blow through carb
dont get me wrong thoe ive seen people run 10 to 15lbs on a stock motor to but WHY and for how long will she live
ps check that vette carb the didnt come with alot of power back then
New2Chevy
Sep 28, 2015 12:35 AM
