how much horse power does a stroker add to a 305
I have 84 z28 stock its what 190 hp I'm trying to get it in the nieborhood of 350 hp or higher is the stroker gonna add a lot more hp to the car and how much hp does it and how can I reach my goal?
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Re: how much horse power does a stroker add to a 305
you need to do alot of reading and research... if you want power get a 350
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
It will give you more TQ than HP however using a motor with a 4" bore will be the most cost effective way to achieve POWER across the board. No trying to get a 4" bore from a 305. Block either it does not work..........
mhatfield 14
Oct 24, 2015 07:48 AM
