NGK Plug question
Old Feb 17, 2011 | 09:42 AM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Transmission: TH 700R4 or TH 7004R
Axle/Gears: Moser 9" 370:1
NGK Plug question
I have AFR 1038 heads a D1SC SC, and hooker comp plus headers on a 1986 Camaro. I am tryomg to fing out what NGK plugs I should use. I will be using a lot of boost, but the car needs these plugs to start. I inderstand that the thread length is 3/4", gasket, but I am hoping someone can tell me if there is a shorter plug so I don't burn my MSD 90* wires.
Thanks,
Steve King
Old Feb 17, 2011 | 04:11 PM
Ronny's Avatar
Re: NGK Plug question
Accel makes "shorty" spark plugs. Maybe others do too. Why not buy insulating booties?
Old Feb 17, 2011 | 04:16 PM
spkx714's Avatar
Car: 1986 IROC Z
Engine: 383/D1SC
Thanks Ronny, I am under the impression that, even with the booties, the wire has to be replaced every 1000 miles. Am I wrong about that? Thanks for the tip about accel.
Old Feb 17, 2011 | 04:20 PM
Ronny's Avatar
I dont know. I presume more than 1000 miles. Double wrap ?
Old Feb 17, 2011 | 04:51 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I have had good luck with protective sleeves on header applications. Of course your supercharged setup will make more heat in the header primaries than most NA motors. I hate ACCEL ignition parts but you may not have much choice. It seems I have seen other brands of short plugs. Perhaps a search on Summit's website might reveal something.
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
