377 Turbo HSR
Old Feb 26, 2011 | 09:43 PM
andre1dre's Avatar
Car: 88 T/A GTA
Engine: 377
377 Turbo HSR
Has anyone used the holley Stealth Ram intake with the Avenger EFI, HP EFI, or Dominator EFI, on a turbo motor? If so how easy or difficult is it to get setup and dialed in with the timing and fuel curves
Old Feb 27, 2011 | 09:15 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Re: 377 Turbo HSR
My dream is simple
Twin T04e 50 trim 48ar
HSR, C950, roller 228 @ .050 with .499 lift weak spring 112LSA
random 180-190cc runner aluminum head
9.0:1 compression
under 6,500 RPM
600RWHP
displacement maths:
355 x 6000 / 3456 = 616 * .069 = 42lb/min naturally aspirated with perfect VE
so dump VE to 90% then jack the boost to 15PSI:
355 x 6000 / 3456 = 616 * .90 = ~1100CFM * .069 (turbocharger constant) = ~760 horsepower
should be good for 600RWHP after drivetrain losses, and compressor efficiency losses.
pump gas 93 octane just intercooler it.
Weak spring low lift for longevity, get a head with good flow @ low lifts and small enough ports to maintain velocity.
With the right transmission, I am thinking 700R4 2800 Stall, 9.5" lockup converter (go probuilt!) this would be a scary vehicle
now put it into something very light like a 240sx (2800lbs)
Old Feb 27, 2011 | 11:14 PM
andre1dre's Avatar
Car: 88 T/A GTA
Engine: 377
Re: 377 Turbo HSR
Nice sounding setup
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
mike22115
Sep 28, 2015 04:49 AM
New2Chevy
Sep 28, 2015 12:35 AM
