any body make ebay single turbo headers work?
Old Mar 14, 2011 | 09:42 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
i have seen some people talk about having them but dont seem to see that many pics of the final set-up done, so do they work with a straight plug or angled plug heads? what kind of work should be done to them to make them work better?
Old Mar 14, 2011 | 08:30 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: any body make ebay single turbo headers work?
angled plug would be better and you would need to run the short accel or equivelent header plugs. if you run straight plugs you will need to modify the #8 primary tube seeing as you will not be able to get a plug in or out nor install a plug wire. also the crossover from the driver side to the passenger side will need to be modified .
and if you run tall valve covers, alternator or ac on the passenger side forget about that . some fabbing will be necessary to make things work correctly. i know because i actually found a way to make it work . at the moment i have changed setups to relocate a few things the top picture is current as well as the bottom picture the location of the turbo
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
1984HO
Mar 19, 2021 11:59 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
