Vortech V1 on L98 - question!
Old Apr 8, 2011 | 02:28 PM
shone190's Avatar
I was wondering, is it possible to put Vortech V1 supercharger on L98 without ECM modifications?
Old Apr 8, 2011 | 03:11 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Re: Vortech V1 on L98 - question!
why would you want to do such a thing?
Old Apr 8, 2011 | 03:14 PM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
Yes you can put a Vortech on the L98 with out programing the ECM. Just dont drive it.
Old Apr 8, 2011 | 03:19 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Yes, but it requires the usage of Vortech's adjustable FMU. Primitive, yes, but it works. Note though that if you change injector size, you'll need a new chip regardless, so your better off just having someone burn you a chip for larger injectors, then running the FMU. Or, scrap the FMU altogether, and burn the right chip with altered MAF/MAP and Alpha-N tables....
Old Apr 9, 2011 | 01:42 AM
shone190's Avatar
For the example, I saw on this site (http://www.ehow.com/about_6390287_di...ercharger.html) part of text:
On many domestic fuel-injected V-8s, a centrifugal supercharger can add almost 100 horsepower without even reprogramming the computer.
That's the reason I asked
Old Apr 9, 2011 | 05:21 AM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
If you were to put that on and not tune it... id give it a few weeks before the engine was trashed.......
Old Apr 9, 2011 | 10:53 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Vortec and all the others do sell their kits with no computer modifications, not sure why everyone is all freaked out. Usually you will get a FMU and a fuel pump with it, also maybe a ignition/boost control unit for your spark retard in the kit. Those 3 things will work on the car for years but to get the most out of your supercharger a change to the ECM or aftermarket computer would give you full control.
Her are some instructions for the TPI Vortec kit to give you a idea http://www.vortechsuperchargers.com/...e=4GF218im.pdf
My85TA
Nov 30, 2002 03:02 AM
ATTNGETR
May 13, 2002 08:21 AM
brettd
Jan 25, 2002 12:54 PM
fastrax
Aftermarket Product Review
Oct 22, 2001 09:14 PM
Forced_GTA
May 29, 2001 04:47 PM
