Direct port TPI jet sizes
Old Apr 18, 2011 | 03:20 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I recently picked up a used kit.
http://cgi.ebay.com/ebaymotors/TPI-N...item20b8886510
I didn't plan on it but I used to drool over these things. I am going to replace/rebuild the solonoids and buy all the necessary parts to make it work. I am trying to find out where to get info on what size fuel and nitrous jets I need. I would probably be running a 100 to 150 shot.
I might contact NOS and see if I can get some info.
Old Apr 20, 2011 | 09:34 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Direct port TPI jet sizes
Use a nitrous jet calculator online. If you run typical 43.5 psi fuel pressure and 900 psi bottle pressure, and have 8 nitrous ports for direct port system and only want to run 150 whp shot total, then you will want around a 0.022-0.023" nitrous jet and around 0.012" fuel jet.
http://www.robietherobot.com/NitrousJetCalculator.htm
Old Apr 20, 2011 | 03:25 PM
Ronny's Avatar
NOS site has what you need in instruction manual.
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
knight72
Aug 10, 2015 09:32 PM
