Do I have to run a electric feul pump with a Aeromotive A1000 Carbureted Bypass
Old Aug 24, 2011 | 12:56 AM
irocsupercharge's Avatar
I am going to run 10psi on a chevy 355 blow through Holly 4150 with a 13204 - Aeromotive A1000 Carbureted Bypass Regulator. Do i have to run a electric fuel pump or can I run the mechanical fuel pump with the A1000?? Thank you for you time and help.
Old Aug 24, 2011 | 05:22 AM
DIGGLER's Avatar
Re: Do I have to run a electric feul pump with a Aeromotive A1000 Carbureted Bypass
i would think a mechanical pump would work. not sure if there would be any problems with the regulator making noise or chattering from the flow being so much less than an a1000 though.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
beachrodder
Aug 25, 2015 08:05 AM
st.evel07
Aug 13, 2015 06:15 PM
