Need some turbo help.
Old Nov 25, 2011 | 12:55 PM
91kbell's Avatar
Well i recently picked up the hotside for twin hx35's on a third gen from craigslist, the setup is obviously not the best thought out system but it worked for the PO's purposes. For 150 bucks ill take my chances. id love to upload some pics but have no clue how, if i could email the pics to someone and get them uploaded that would be amazing so you guys could see what i have to work with. i plan to make a crossover to connect both headers and run a single hx35 and i need your creativeness!!!!
i also have a couple other questions like can i get my oil feed from the small port above the timing cover in front? i figured another member would have used it by now, but havent seen it in any previous builds.
Ive never heard of Sanderson headers but thats what the ones i bought are, Poor Quality? they look to be decent, any input is appreciated!
Thanks, Kaleb.
Old Nov 25, 2011 | 01:51 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Need some turbo help.
go to http://tinypic.com/
upload your pics there then beside the pic you will see a link for message boards copy that link an paste it here it will show up as a pic .
Old Nov 25, 2011 | 02:13 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
the quality isn't bad, they are based out of san francisco I think, they do a bunch of old school and rat-rod type stuff. Im using them for my turbo build. their customer service however... TERRIBLE.
Old Nov 25, 2011 | 02:58 PM
91kbell's Avatar
thanks for the pic advise freaky and header info, Tex.
Old Nov 26, 2011 | 06:05 PM
91kbell's Avatar
ill get some pics up sometime soon, i think i found my fuel pump and regulator. do you guys think these will be sufficient? any input is appreciated, here's the pump:
http://www.shopatron.com/products/pr...AER11142/415.0
and regulator:
http://www.shopatron.com/products/pr...AER13301/415.0
There's no one around me that makes braided lines fr the oil supply so who could i order them from?
Old Nov 28, 2011 | 11:39 PM
91kbell's Avatar
come on guys, nothing??well i have more questions
with my very low goal of 400WHP would this diff and some new bearings hold up for a year or so with no sticky tires? its an auto too so the rear shouldnt take a huge beating.
http://www.ebay.com/itm/REMAN-7-5-7-...item3cbf161ff5
seems like a decent deal and you get 75 bucks back if you return your old one.
one more question tonight, i bought a torque arm package off of fleebay that has the short style torque arm and plate that bolts to the floor pan. the plate has a "finger" that the torque arm slides onto and the finger has a couple holes in it.once mounted, i figured that there would be a pin that slid through the torque arm and the finger and i could press the plate against the floor, marks my holes, drill, Etc. BUT there is no hole in the torque arm so how do i know where too mount the plate? sorry if this is confusing and sounds like a dumb question but i figured if mounted incorrectly this could cause serious issues. please give me some input guys im really trying to learn alot with this build!!!
Old Dec 8, 2011 | 09:34 AM
Patrick Day's Avatar
The easy way to up load you pics here is when you add to this post just click the go advanced and then click on the paper clip attachment , Then click brows it should go to your personal pic. and pic out the pics you want
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Numbah-1
Oct 2, 2015 08:27 AM
New2Chevy
Sep 28, 2015 12:35 AM
