Procharged 88 GTA
Old Dec 7, 2011 | 05:22 PM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Procharged 88 GTA
I'm currently in the process of adding a D1SC procharger (intercooled) to my 383 GTA (looking @ running 8-10 PSI to start and hope to get up to 16-18 PSI in the long run). The 383 was built with the idea of putting a blower on it as far as cam, compression ratio and etc. I have looked through alot of pictures on the site of people adding prochargers to there "stock" motors with the TPI set up (not all, but most).
I'm doing something a little bit different (or atleast I'd like to think so, maybe I'm not), I'm going with the carb set up instead. I have a C&S 850 blow thru carb that I will be using and hoping to hear from anyone that has been down this road before. I have a couple of small hurdles to jump over at the moment as far as the install goes, but I was really looking to hear or see some pics. of carb. setups like mine.
Thanks in advance, I will post some pics in the up in coming weeks.
Old Dec 8, 2011 | 12:02 AM
daverr's Avatar
Re: Procharged 88 GTA
with forced induction it is best to go efi. yes it can be expensive but you`ll save yourself from the bogging,sputtering,flooding a blowthru carb will give you.
Old Dec 8, 2011 | 09:51 AM
Car: 88 GTA, 74 T/A
Added some pics.
Attached Thumbnails Procharged 88 GTA-mount-pleasant-20111206-00088.jpg   Procharged 88 GTA-mount-pleasant-20111206-00089.jpg   Procharged 88 GTA-mount-pleasant-20111006-00023.jpg
Old Dec 8, 2011 | 09:55 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Nice looking GTA...
Old Dec 8, 2011 | 09:56 AM
How does it run with the dual plane Edelbrock manifold?
Old Dec 13, 2011 | 09:47 AM
Car: 88 GTA, 74 T/A
Not too bad, its good for low end power (good street intake). I will be putting the victor jr. back on for the procharhger set up. The motor is @ 8 1/2 to 1 comp., the best time I got with it was 12.93 @ 107. Who knows what it really could have ran, I smoked the transmission at a pontiac event back in October (only had 1st and reverse). Getting ready to pick up my transmission from TSI transmission in chicago this weekend.
Old Dec 13, 2011 | 10:01 AM
I got ya. I thought you were running the dual plane with the ProCharger as that is why I asked because I was considering running a dual plane w/blower on another project. She is coming along sweet...
Old Dec 13, 2011 | 10:05 AM
Car: 88 GTA, 74 T/A
I just started reading your post on Chronicles of a 9 Second 305 Trans Am, Can It Be Done, pretty interesting stuff!
Old Dec 13, 2011 | 10:09 AM
Thanks. So much has changed with that build, as I'm considering starting a new thread now because the engine is going in a GTA instead of that Anniversary Trans Am. Would like to get it on the dyno very soon though either way, but work has been killing me lately...
Old Jan 17, 2012 | 11:19 AM
Car: 88 GTA, 74 T/A
Some more pics.
Attached Thumbnails Procharged 88 GTA-mount-pleasant-20111216-00111.jpg   Procharged 88 GTA-mount-pleasant-20120115-00154.jpg   Procharged 88 GTA-tampico-20111231-00133.jpg
Old Feb 14, 2012 | 08:33 AM
Car: 88 GTA, 74 T/A
Update: Just fired up the car this past saturday, wow what a difference, throttle response is 10 times better than before, which is to be expected being the motor was originally built as a blower motor. I also bought the FAST air/fuel ratio gauge with the dual sensors, haven't took it out and drove it yet, waiting for all of salt to be washed off of the roads. Still need to get the new MSD box hooked up which is boost referenced as well.
Attached Thumbnails Procharged 88 GTA-img-20120212-00198.jpg   Procharged 88 GTA-mount-pleasant-20120212-00199.jpg
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
