turbo help
Old Dec 9, 2011 | 01:01 PM
zayne0's Avatar
Car: 1992 camaro RS
Engine: 5.3 lsx
Transmission: 4l60, soon to be t-56
turbo help
Alright here's what I have:
92 Camaro RS
spohn k frame
ls1
4l60 trans
Corvette belt system
I want to run a t76 turbo I want to know whats the best route to take? Make my own forward mainfolds? Use factory ones and flip them forward. My plan is to make it rock solid a/c still working all that... Please help! All insight much appreciated! THANKS ZANE
Old Dec 13, 2011 | 12:03 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: turbo help
I cut then brazed a set of cast manifolds, worked fine. However, I had to get the flanges resurfaced though because they warped a tad, so keep that in mind if you decide to go that route...
Old Dec 13, 2011 | 01:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: turbo help
Moved from Engine Swap to Power Adder.
Old Dec 13, 2011 | 02:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: turbo help
My buddy had a 4th gen with a stockish LS1...mild bolt ons and LS6 cam swap. GT4202 turbo which is about 74mm. 550+ whp with 11-12 psi. Fun car. Think he used basic logs or even factory manifolds but you need to see what room you have in that car.
Not sure the factory manifolds flipped forward will clear everything. If you want AC and using stock accessories, you may need to fab something to gain the room you need. With the motor in the car already, you can easily see what you need to do.
With the bottom end stock, you dont want to get crazy with the boost. Simple log header will work. My other friend has made 700+ hp on a simple log on his turbo truck builds.
Old Dec 13, 2011 | 06:15 PM
zayne0's Avatar
Car: 1992 camaro RS
Engine: 5.3 lsx
Re: turbo help
How thick were the flanges you brazed? what grade were they?
Old Dec 13, 2011 | 06:18 PM
zayne0's Avatar
Car: 1992 camaro RS
Engine: 5.3 lsx
Re: turbo help
Yeah my friend kyle says I could run a t76 and make 500 easy. I'm looking at some compound setups I think that would be pretty sick.
Old Dec 13, 2011 | 06:42 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: turbo help
the ls1 4th gen f-body use a lsx truck passenger side manifold flipped forwards on the drivers side, and a corvette manifold on the passenger side when they want to keep A/C. Also most of them just weld v-band flanges to the cast manifolds
Old Dec 14, 2011 | 10:31 PM
zayne0's Avatar
Car: 1992 camaro RS
Engine: 5.3 lsx
Re: turbo help
Alright, I can't decide between twin 50mm or a single ball bearing t76... I'm torn.
Old Dec 15, 2011 | 08:59 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: turbo help
May want alittle bigger than twin 50's. I believe a 76mm can flow 95-105 lbs a minute depending on model/brand. To match that with twins, you'd want twin 57-60mm. Garrett GT3076 would fit. Its got a 57mm compressor wheel, and 60mm turbine wheel which is alittle smaller than a P-trim turbine found on alot of units like master power and such... they support a good bit of power. Should be a nice combination for up to 800/maybe 900 hp or so.
If you only wanted 500hp or so, those 50-52mm small units would kick butt and spool sooo fast.
Old Dec 19, 2011 | 05:20 PM
zayne0's Avatar
Car: 1992 camaro RS
Engine: 5.3 lsx
Re: turbo help
Yeah true. So I've decided to run manifolds flipped forward and tig my own stainless piping and flanges. From what I've read 304 ss should be sufficient. Is this a good choice?
Old Dec 19, 2011 | 07:40 PM
Re: turbo help
I'm showing this picture so you can see where it was brazed, as now they are coated with T4 flanges also brazed up top. Are you asking what grade the aftermarket flanges are, what grade the stock exhaust manifolds are, or what grade the braze that I used is...?
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
