Trying out a Small Turbo
Old Feb 7, 2012 | 12:10 AM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
Just bought a GT4294 Turbo today, and am pulling my P600B (for sale) off and putting it on. Upgrading my fuel system and getting a different computer system. (Holley HP Efi). here are a few turbo pics, more to come.
turbo
came out of a 4th gen, im gonna see if the hot pipes will work in my car. here is the set up in the previous owners car.
and the wastegates i recieved too. 44mm
Old Feb 8, 2012 | 04:26 PM
project89's Avatar
Re: Trying out a Small Turbo
i hope u didnt pay to much for that setup, thats an ebay turbo and ebay wastegates etc
Old Feb 8, 2012 | 09:35 PM
Paid $800. How sure are u that it's an eBay turbo.
Old Feb 8, 2012 | 09:52 PM
project89's Avatar
well if the hotpipes work on ur car it thats not a bad price
but that turbo goes for 450 bucks on ebay
wastegates about 50 bucks each
the blue tag and gold compressor nut on the compressor side are a dead giveaway
the tag says gsp on it
gsp sells the typhon 72mm turbo and the t76 turbo along with others on ebay
u apear to have the 72mm typhon turbo
Old Feb 8, 2012 | 10:23 PM
hmm. well thanks for the info. we will see how it does on my car. i am looking it up right now, cause im sure if it was a garret it would say it on the tag.
Old Feb 8, 2012 | 10:32 PM
http://www.ebay.com/itm/Universal-T4...item27c3177321
think i found it. looks identical, except i think mine has more of a polished looking turbine section.
Old Feb 9, 2012 | 09:47 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yeah, yours is an ebay turbo.
YIKES! Someone cut off the outlet flange. I hope you can get a hose & clamp on the end to hold the charge pipe on there.
Not the nicest welds but it looks like they will hold.
Old Feb 9, 2012 | 09:53 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah may need a bead welded around that discharge area to get a good clamp connection. Alittle bit of a grinding wheel to rough up the surface and alittle hairspray or some sort of rtv sticky material to help hold it on would help with a good T-clamp.
Old Feb 9, 2012 | 12:23 PM
thebuffalo's Avatar
Car: 88 trans am
Engine: 350sb
Transmission: t400
Axle/Gears: 7.5/2.73
Small turbos spool faster!! Good stuff.
Old Feb 9, 2012 | 12:45 PM
Junkcltr- ya I'm gonna try cleaning up those welds, and re fab some of the pipes with my own worm welds haha. And ya I was kinda disappointed they cut it off. I'll figure it out when I get closer to getting the turbo on.
Orr- ya i may have to try something like that.
Old Feb 10, 2012 | 11:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I think if you weld a bead on the end like Orr said then it will be fine. If that is a copy of a GT4294 then that turbo should be almost 70mm which is plenty big enough. I wouldn't worry about the welds. It looks like schedule 40 pipe. Maybe just clean them up with a grinder if you don't like the looks of them.
Old Feb 11, 2012 | 12:35 AM
ok, so im trying to get a few things figured out. im doing it out of either my dads garage or my moms apartment garage, so i dont have anything nice like a tig welder,....
im using my brothers wire feed welder, and it has some flux cord wire in it, will it be fine welding stainless steel?
also, those wastegates, should i look into some different ones since those are "ebay" ones? or will they be alright
and the other thing is im not sure what size injector im gonna run. i asked the guy i bought the turbo from and he thought i should go with a 90lb low impedance injector.. what do any of u guys think?
if u guys could give me some advice i would apreciate it. ive welded before but not stainless steel stuff, and dont wanna be trying to weld something that wont weld if that is the case..
here is some of the specs of my setup, for thinking what injector size-
383 AFR 195s, GT4294 wanna run 10-15 lbs, (starting out around 7lbs), not sure on the cam specs, ummm.... im gonna buy the Holley Hp Efi system, Aeromotive A1000, sump, 8AN feed, 6AN return, holley stealth ram, .. that about all i can think of.
let me know what u guys think.
THANKS!!!
Old Feb 11, 2012 | 12:56 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
single 70mm, figure 650whp tops or so, maybe 700. I run 80's on my car but for that power you can squeeze it in 72's. Possibly 60's that are rated at 43.5 psi and run at a 58psi base pressure to make them act closer to 70's. Those would work.
High impedance will be fine with code 59 if you use that. Dont recall what you ended up using?
It aint the greatest for SS and TIG is better for it, but it can work. I've done it before.
I'd run something like my old cam, single pattern 230 deg or so on a 112-113 and call it a day.
Comp cams magnum 280 hydraulic roller but on a 112-113 would be a nice streetable smooth cam for a turbo car IMO.
Old Feb 11, 2012 | 01:15 AM
i never did tune it, but im gonna give the holley system a shot. also, how much did ur 80lb injectors cost? and whats a good place to shop injectors?
guess ill give it a shot. see how it turns out.
im gonna stick with the cam thats in there for now, then save up and buy something else. but ill keep that in mind when i do look at cams.
Old Feb 11, 2012 | 02:15 AM
project89's Avatar
im sure the wastegates will be fine ive used a bunch of the ebay stuff and never had any issues with any of the stuff.
except for one time i took out a seal in a turbo but it was my fault for not using an oil restictor on a motor that made 105+ psi of oil presure
Old Feb 11, 2012 | 11:24 AM
Think I will be alright? I've seen my motor get around 90psi when I start getting on it. After It heats up it will drop but some few times I've seen it that high.
Old Feb 11, 2012 | 02:09 PM
project89's Avatar
u shoudl be fine, u dont want be boosting the motor soon as u start it up anyways, so by the time ur motor warms up and oil presure drops it should be in a good range.
in ur case i would run a -3 an feed line instead of a -4 an feed line.
i never was a fan of running a restrictor on a joural bearing turbo
Old Feb 12, 2012 | 09:51 AM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Can't say anything about ebay turbos, but as for the wastegates your probably fine IF you check it over well first. I've disassembled a few of them and tolerances and overall quality appear good. Where they falter is part cleanup and assembly. I've seen casting flash and machined edges that need touching up first on every one that I've looked at. Disassemble, clean it up, re-lube and you're good to go.
86Firebird86
Dec 26, 2015 07:21 AM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
84 TA NV
Sep 6, 2015 08:02 PM
