Cold air source?
Old Mar 29, 2012 | 01:29 AM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
Cold air source?
Anyone picking up cold air from under the "pass side battery tray?"
Thinking of putting a 4“ pass-through and mounting the air filter down there. May put a small airdam too.
Any thoughts on water?
Thanks again
Old Apr 4, 2012 | 11:53 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: Cold air source?
That is where I am pulling air from at the track only. But, I am using the side with the carbon canister instead of under the actual battery tray.
I have tubing running from the fog-light opening up through the tray to the intake with no filter for the track only. On the street, I disconnect the pipe right at the tray and put a cone filter on it.
It's not pretty, but in back to back tests at the track I picked up almost 2mph and .15 or so with/without.
Old Apr 4, 2012 | 08:42 PM
BANDITSBC's Avatar
Car: 90 gta
I got mine installed and happy with it, mine is also on canistet side.. anything is better than the cone right off the Turbo behind the radiator!
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
