Anyone using tall valve covers with a Procharger?
Old May 30, 2012 | 11:33 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
As the title says, got a few questions regarding things fitting
Old May 30, 2012 | 03:43 PM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Re: Anyone using tall valve covers with a Procharger?
Yes, I use them.
Attached Thumbnails Anyone using tall valve covers with a Procharger?-img-20120204-00179.jpg
Old May 30, 2012 | 04:24 PM
Twin_Turbo's Avatar
Here too:
Old Jun 1, 2012 | 10:37 AM
Car: '92 RS Camaro
Transmission: TH400
Ok then Right, firstly, Im using the aluminium brace which bolts the Procharger plate to the alternator. How does the original serpentine brace fit now, as mine seems to foul?
Also, the alternator positive connection seems very close to the valve cover, how did you insulate this?
Old Jun 1, 2012 | 10:42 AM
Twin_Turbo's Avatar
A small plastic cap on the terminal, does your alt have a threaded post on the back or one of those mounting blocks where you screw down the connection with a screw from the top?
Old Jun 1, 2012 | 11:02 AM
Car: 88 GTA, 74 T/A
I had to take my alternator apart rotate the back half to make it work, you also might have to use to washers on the back side of the alum. brace to the alternator.
Attached Thumbnails Anyone using tall valve covers with a Procharger?-mount-pleasant-20120307-00204.jpg
Old Jun 2, 2012 | 12:31 PM
Car: '92 RS Camaro
Transmission: TH400
My alternator has a stud, Ive already cut this down, so will probably put some sort of cap over it. With the brace, it fits ok, I meant the brace for the back of the alternator down to the head, the original serpentine one
Old Sep 5, 2012 | 04:29 PM
86TA355SR's Avatar
Car: 88, 89 & 91 GTA
Engine: 355 Super Ram/350
Transmission: TH-375/700R4
Axle/Gears: Currie Ford 9"/3.70
Who owns the black 92 GTA? I have saw that car on YouTube, it is awesome!
Old Sep 5, 2012 | 05:02 PM
Twin_Turbo's Avatar
My buddy, 69Cyclone owns it, I built it.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
