Good plugs for AFR heads and procharger
Old Jun 17, 2012 | 08:26 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I've spent about an hour researching plugs, but still no winner. I need:
Resistor plug
Gasket seat
1 heat range colder than stock
Not sure if I should get "shorty plugs" or not, I haven't seen my wire clearance to the Edelbrock headers.
Anyone have a successful plug with the same setup as me?
Old Jun 17, 2012 | 08:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Good plugs for AFR heads and procharger
NGK TR6 (I think) dub check it on prochargers site.
Old Jun 17, 2012 | 09:27 PM
Car: 89 GTA
Axle/Gears: 4.10
That is a tapered fit though. I need a flat gasket seal for my aluminum heads.
Old Jun 17, 2012 | 10:19 PM
TTOP350's Avatar
From the AFR web page.
http://www.airflowresearch.com/sbc_install.php
13) Spark Plugs:
(14mm x 3/4" gasket) no tapered seat style. For race applications Champion C59YC Autolite 3910 or 51, A/C R41 CXLS & NGK R5672A-9 is a good starting point. For street applications use AC FR3LS, AC 41629, or Champion RC9YC spark plugs or equivalent. Plug selection is of course dictated by many factors including rpm level, compression ratio and type of fuel. All the above plugs are a starting heat range, blowers or nitrous application usually 1 to 2 heat ranges colder. Spark plug gap should be determined by the ignition manufacturer.
I run a NGK TR55 in my AFR heads, always have.. I'm thinking if you call AFR they will tell you what you need to know.
I also remember reading some place that the AFRs are cut for both types of spark plugs. I'll check my new instructions that came with my AFR 235 Eliminator heads.
Old Jun 17, 2012 | 10:52 PM
Car: 89 GTA
Axle/Gears: 4.10
From AFR:
1) Spark Plugs:
(14mm x 3/4" gasket) no tapered seat style! For race applications Champion C59YC, Autolite 3910 or 51, A/C R41CXLS & NGK R41 CXLS are good starting points. For street applications use AC FR3LS or RC9YC Spark Plugs or equivalent. Spark Plug selection is of course dictated by many factors including RPM level, compression ratio and type of fuel. All the above Spark Plugs are at a starting heat range; blowers or nitrous applications usually require 1 to 2 heat ranges colder. Spark Plug gap should be determined by the ignition manufacturer.
Old Jun 17, 2012 | 10:57 PM
Car: 89 GTA
Axle/Gears: 4.10
I found one of the colder gasket plugs by NGK, it's a little hard to find, but plenty on Ebay. This looks like a good starting point for aluminum heads/supercharger
NGK V-Power Performance Spark Plugs BKR7E VPOWER # 4644
Old Jun 18, 2012 | 07:24 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I've been using the Autolite 3923's for years.
CRFred
Feb 7, 2016 11:39 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
