camshaft selection on turbo build
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
so the motor will be a 355 8.3:1 compression, motown 220 heads and a victor jr intake. at this point im not sure on if im doing single or twins. i have a single turbo header and im having project89 price out making me a set of twin headers. planning on running max of 14psi on pump gas
as far as cam goes im looking at either a summit 224/224 cam or this comp cams mechanical roller.
http://www.jegs.com/i/Comp-Cams/249/...oductId=758230
my heads are already set up for mechanical roller cams and i have the lifters and roller rockers already so the difference in price is $200. my main concern was that i wouldnt be taking full advantage of the flow capabilities of the heads at .465 lift.
as far as streetability goes, i would like it to...
want to idle
i dont care about fuel economy and how often i have to lash the valves either. ive done it before and can do it again.
oh, other important stuff- trans, i will be switching to a glide with 4k stall and 3.42 gears
want to idle
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: camshaft selection on turbo build
Call Mike Jones and talk to him about your build. He will be able to grind you something that is suitable for your goals. Shelf cams are for people that are lazy, and you're only hurting your drivability/power potential by using them... all while paying the same price.
Car: 1991 camaro rs
Axle/Gears: 3.42s
Sounds good, who is he and how do i reach him
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
http://www.jonescams.com/2006catalog_001.htm
www.straubtechnologies.com
Talk to Chris
Either one of these guys will get you the right one the first time.
Crower is good with this also
Google them in San Diego, Ca.
Talk to Chris
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Talk to Chris
Talk to Chris
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Set your power goal and rpm range and then look for the cam thru one of the custom guys. What kind of exhaust side you plan on using? Log mani vs actual tube headers will change cam spec because of backpressure expected. Turbine spec as well, blade diameter and housing a/r etc
Car: 1991 camaro rs
Axle/Gears: 3.42s
Im torn between 2 motors right now, i have a 406 that has 9:1 compression already but has hyper pistons and the 355 which will need pistons regardless. I am free to use either one and im not sure which one. I have decided to use e85 since it is hard to find a set of off the shelf pistons under 8:1 compression with 64cc heads. If i go the twin route with the 406 i will use twin t70s. either way i am looking at similar build costs.
What compression should i shoot for with iron heads and e85?
Car: 89 Iroc-z
Transmission: TH400
10 to 1 would work ok for under 15 psi. 406 will make tons more power and torque across the curve and require slightly bigger cam than the 350 for same rpm range.
Car: 1991 camaro rs
Axle/Gears: 3.42s
Sounds like a plan then, the 406 it is then
Car: 1991 camaro rs
Axle/Gears: 3.42s
ordering pistons tomorrow, decided on these pistons
http://www.summitracing.com/parts/dms-2507x-155
they will put me at 9.25:1 assuming zero deck but i wont have it zero decked to help lower compression( bad part is it will put me out of the .040 optimum quench)
also a set of gapless file fit rings and bearings. the engine already has eagle i beams with arp wavelocs so it should be ok if i keep the revs under 6k
on a side note im having one of my dads buddys come give me a qoute on painting the car, color is crimson red metallic
New2Chevy
Sep 28, 2015 12:35 AM
