39x ls1 with twins but are they right ?
I'll post pics when I can I'm a trucker so buying everything I have a 6.0 block with a wiseco 3.90 inch stroke and custom pistons 9 to 1. Also the block has a main girdle and all arm stud kit. Im running ls3 procomp heads that are cnc'd and running manley valves. A custom grindle cam and a Holley hi ram 102 intake with a 102mm eBay throttle body. The cam is set up to run from 2600-7400 rpms 116 lobe sep and 651 lift which I plan on turning. I'm using obx up and for headers 1.8 yella terra roller rockers. The power goal is 1000 plus rear wheel horsepower. I'm looking at a set of on3 70 mm turbos Turbo Specs
dum
Cold Side:
dum
dumCompressor Wheel 70mm
.70 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer-dumdum 70.15mm
Exducer-dumdum 94mm
dum
dum
Exhaust Side:
dum
Exhaust Housing T-4 Flanged Divided
Available in 2 A/R sizes -dum .68 or 1.0
3.0" Vband outlet
Inducer-dumdumdum64.5mm
Exducer-dum
dum
360 degree Thrust Bearing
I think these would be comparable to a s400-80 for a single any thought or input would be nice I maxed out my cash flow or I'd run the Borg or twin 67 percisions
dum
Cold Side:
dum
.70 a/r
Exducer-dumdum 94mm
dum
dum
Exhaust Side:
dum
3.0" Vband outlet
Exducer-dum
dum
Re: 39x ls1 with twins but are they right ?
stay away from on3,just do a search for on3 on the turbo forums,
iys not that the stuff maybe bad but the guy is a douche and will not honor warrenty
and on that engine i would try not to use chinnesse turbos if u can help it ,that being saud i love chinnesse turbos lol
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Turbos would work i know some guys have used on3 stuff with success. For a good expensive block build, i would rather see some better quality turbos but i have master powers which arent the best out there either...but abit better than ebays imo
Run the 1.0 housing. Probably wont be in good boost til around 4200-4500. My 400 with 330 cfm heads and .640 cam spins t70's by 3600. Sees some boost but not fully energized til 4500
Car: 89 Iroc-z
Transmission: TH400
Would have guessed in the 700's whp on 13 psi but had a bunch of problems. Valvetrain stability which didnt allow me to see full power. It will be up around 1000 next year after refresh hopefully
Car: 92 Z28
Engine: Boosted LSX
with the good built engine I wouldnt chance the ebay turbos. Yes they are hit or miss. You you really wanta take the chance of one letthing go?
Wht not just save a few more bucks and go with two tc76's
Car: 89 Iroc-z
Transmission: TH400
My car, not sure what the issue was. Thinking my pushrod/rocker geometry was off which killed the intake guides and springs...they didnt measure out right on pressure, about 30-40 lbs low using a basic pull lever type gauge. Once motor and heads are freshened up and ready to install on stand, I'll go over geometry again. I think I used too short of a pushrod.... Hard to say.
