Need timing map for Accel Gen 7 w/ supercharged 350
Old Feb 17, 2013 | 03:02 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I'm looking for a street conservative timing map to use with my Accel Gen 7 setup. I'm not looking to squeeze maximum HP out of this car, just a conservative base timing map to avoid detonation on pump gas. I'm running 8lbs of boost with 9:1 compression. You could email me your cal file to dave2brecht@yahoo.com as well
I have a wideband conroller and am running about 12:1 at full throttle/boost. I could probably also fatten this up slightly to 11.5:1?
Old Feb 17, 2013 | 03:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Need timing map for Accel Gen 7 w/ supercharged 350
Just throw in something like 32-34 deg at wot, 100 kpa map before boost ever comes in. Set it to come in around peak torque rpm maybe just before.
Idle depending on cam, run around 20-28 deg or so. Ramp up to 35-38 cruise over 2000 rpm and low maps under 80 kpa.
Boost tables take 1 deg out for each psi boost, so 8 psi you should be atleast 26 deg if 34 at wot 100 kpa. Or go alittle more conservative, 1.1-1.3 deg per psi.
11.5-12.0 air fuel should be ok. Aluminum heads for sure. Iron may want less timing and richer to keep cool but you will have to experiment
Linson
Oct 24, 2025 02:00 PM
FormulasOnly
Jul 23, 2018 08:47 AM
cheesehomer
Dec 31, 2015 08:48 AM
mattcanty
Oct 12, 2015 11:08 AM
Gordonr1973
Sep 29, 2015 11:59 AM
