5.3 turbo build. Any good headers out there?
Old Jul 3, 2013 | 06:52 PM
Frqnkie's Avatar
Car: 1985 IROC.
Engine: LQ9.
Transmission: TH 350 with Hughes 3500 stall.
Axle/Gears: Moser Axles and 4.10 gear.
My plan was to use truck manifolds, and I still probably will, but I was wondering if there were any cheap LS swap turbo headers it there? Post links if you can it would be appreciated.
Old Aug 23, 2013 | 08:16 PM
reaper68's Avatar
Re: 5.3 turbo build. Any good headers out there?
OBX up and forwards, basically a rip off of Stainless works design 5 bills for them.
Old Aug 28, 2013 | 03:41 AM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
^id love to see some pics of that setup.
Here are my truck manifolds flipped.
They do not fit unless you plan on changing some stuff.
The passenger side taps the kmember unless you go to a aftermarket k-member.
It also needs the outer most stud taken out if you get a new k.
The driver side goes right through the steering gear box, so you'd better be running a rack to make that fit.
Old Aug 28, 2013 | 02:10 PM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Here is my setup with the obx headers. It wont post anymore of my pic's. All I would say is if your gonna run twins this is the way to go. But If I were to do it again I wold have gone the manifold route.
Attached Thumbnails 5.3 turbo build. Any good headers out there?-20120318_185618.jpg
Old Aug 30, 2013 | 05:08 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Are those truck or f body manifolds?
Why cant you cut the flange off and change the angle to clear everything?
Old Aug 30, 2013 | 05:59 AM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
I did
Except I just did vbands instead of changed the angles
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wvcamaro
Sep 4, 2015 08:38 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 7, 2015 09:55 PM
