the smog hog pump
Old Aug 21, 2013 | 07:32 PM
ricci66's Avatar
the smog hog pump
anyone have a somewhat educated guess on hp to drive the smog hog pump?
Old Aug 22, 2013 | 10:01 AM
GenX'Motorsport's Avatar
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
Re: the smog hog pump
1-3
Old Aug 22, 2013 | 11:16 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Sadly for some of us that may be significant!
Old Aug 30, 2013 | 08:02 PM
91rs-t-tops's Avatar
Car: 91 Camaro Rs
Engine: 3.1 v6
if you remove it let me know how it goes i want to remove mine for room i have no emissions siffing testing here so it will be fine to remove it. Removing it wont be too bad just have to find the correct belt for it.
Old Aug 31, 2013 | 03:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Best way to go is to find a '87 - '89 2.8l automatic 3rd gen in the JY. They used an idler set up in place of the smog pump. Grab the idler set up and can then use a stock belt for the same car.
The idler is important when running A/C, it prevents that long length of belt on that side from whipping. If no A/C it is still better to have it, but it isn't as critical.
RBob.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
