Procharger guys need a spring tensioner, video and tensioner setup inside!
Old Jan 9, 2014 | 08:54 AM
  #51
Dr X's Avatar
Re: Procharger guys need a spring tensioner, video and tensioner setup inside!
The Procharger tensioner is only made to go to the first line, or between the first and second as you mentioned. That is a predetermined belt tension for most of the dedicated drive systems. You have to remember, that tensioner meant to be used as a two part system with a manual tensioner, as shown in the pictures of the SBC kit and 5.0 Mustang with the bolt protruding above and behind the bracket. It would take quite a bit more work to get the system to bolt up in the manner it was intended, but it appears that your current solution is working quite well.
Old Jan 9, 2014 | 09:11 AM
  #52
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
Originally Posted by 85Iroc-Z
A few other pictures would really be helpful. Thanks
I can try and take some more pictures, but everything is packed in pretty tight. I'lll try and get some pictures posted in the next couple of days.
Old Jan 9, 2014 | 01:09 PM
  #53
Procharged GTA's Avatar
Car: 1991 Trans Am GTA Drag Radial Car
Engine: F-2 Procharged 18* 434 sbc on Alky
Transmission: Powerglide,Neal Chance Converter
Axle/Gears: Moser 9" Ford 3.50's,35 spline axle
That would be fantastic, as we are getting ready to install this also....would love to see as many pics as possible. Thanks in advance!!
Brian
Old Feb 19, 2014 | 01:26 PM
  #54
Anybody have any other pics of this?
Old Feb 22, 2014 | 07:40 PM
  #55
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Is there anything particular you want pics of?
Old Mar 4, 2014 | 08:25 AM
  #56
Hi Tony...sorry for the delay, as i just saw your response....it would be nice to see some close up pics of how the tensioner is clocked..... and just any other pics really....i like to look at alot of pics when doing stuff..it really helps out lot... so anything would be great!
Thanks Tony,
Brian
Old Mar 4, 2014 | 11:40 AM
  #57
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Same here, it is almost impossible to find really clear, comprehensive and detailed pictures of procharger setups on here. There are a lot of "engine bay" pics, thats cool to see to, but when you are building a setup and want some advice the cool pics mean diddly....
Old Mar 4, 2014 | 11:41 PM
  #58
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I have alot of pictures....
my current bracket + holder
http://s373.photobucket.com/user/gta...61152863422746
Tensioner
https://www.thirdgen.org/forums/powe...ioner-ati.html
IC "not decided if I'll keep this setup or net"
https://www.thirdgen.org/forums/powe...-pictures.html
what would you like to see?
Old Mar 5, 2014 | 03:30 AM
  #59
Tony89GTA's Avatar
Car: 89 GTA
I'll have to get some for you in a few weeks then, I'm out of town at the moment for work.
Gta324 did one step farther and made his own bracket, it's a pretty cool setup.
Old Mar 5, 2014 | 11:57 AM
  #60
That would be awesome Tony!! Thanks in advance...I will be waiting ..... and GTA324, thanks for those great pics! It seems your tensioner is mounted different than Tony's setup....Nice job on the bracket also! We will be using the same setup as Tony has, the factory Procharger bracket along with the Dayco tensioner and 12 rib pulley.....
Brian
Old Mar 6, 2014 | 06:58 AM
  #61
Engine: LS3
Is there anyone that has pictures of a bracket not made from sctrach? I love custom stuff just as much as the next guy, but I am in a unique situation right now. My car is in pieces as I am getting ready to do a minitub, my motor was acting crazy last time I had it in the car and I also had wiring issues. With that said, my plan is to do the body and wiring stuff myself, then get the motor dyno tunned with the SC on it. Since I am up to my eyes in work for the body, I want the motor to get a full tune on the dyno with a non-flexing bracket.
gta324 - I appreciate all the pics/links and help, but 1. I don't have the tools to make something like your bracket. 2. I am not sure I even have the skill to be honest.
I know people have said they use ASSC brackets and it works, others have mentioned some place down in RI that makes some sort of bracket and pulley, but no info is ever concrete. Just people saying halfway stuff like, call this guy he will help you out...
I guess just like any other aftermarket product or vendor review I am hoping to find someone that says: I was running an F1 with a 12 rib TPI bracket, got belt slip with the 3.4" pulley, added X from company Y and re ran the car on the dyno and BAM, good booste till redline.
That is what I am looking for... might just be a dream though since there are so many variables and people are running different things based on their skill level of manufacturing.
Thanks for any insight if anyone knows of a car or thread like the one I am describing above.
Old Mar 6, 2014 | 08:04 AM
  #62
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by dennisbernal91z
added X from company Y and re ran the car on the dyno and BAM, good booste till redline. That is what I am looking for... might just be a dream though
No dream, just takes $$$$. I'm sure that the boys over at House of Boost can build you one, but if they do, and I stress if they do... mainly because everyone seems to focus on just the LSX stuff now, it definitely won't come cheap. Their cog drive setup is the strongest I have ever seen, but for the LSX. Don't see why they can't build one for the SBC, but I can only imagine what the cost would be like, and if they would even do it as a one off. But then again, money definitely talks, and it doesn't hurt to ask them...
Old Mar 6, 2014 | 11:52 AM
  #63
Engine: LS3
Beutiful piece.
Old Mar 6, 2014 | 11:57 AM
  #64
It really is a work of art, and their F2 Corvette that showcases it is a monster...
Old Mar 25, 2014 | 06:21 PM
  #65
DIGGLER's Avatar
here's the ysi LT1 i've been working on. i made the motor plate, and incorporated the accessories onto the passenger side. the blower bracket is a part of the drivers side motor plate, and ties to the engine block and frame. 3/8" motor plate, 1/2" blower plate, and 3/4" supports. it all fits under the stock z28 hood. still very unfinished, and tons of stuff to fix/complete.
the 30mm cog drive looks puny, and it will be at its limit, which is why i added the 2 idlers. my thought was to keep the belt from slapping around near the blower pulley. there needs to be maximum tooth contact to avoid ripping them off the belt.
Old Mar 26, 2014 | 07:52 PM
  #66
Tony89GTA's Avatar
Car: 89 GTA
Nice custom bracket Digger, I take it the alternator is mounted low and to the left side of the engine?
Well I took some more pic's, not sure it will help any but here they are.
Old Mar 28, 2014 | 08:19 AM
  #67
Thanks Tony!! That helps alot...i appreciate you taking the time to do that for us!!
Old Apr 13, 2014 | 08:12 PM
  #68
DrkHwk's Avatar
Car: 02 Hawk
Engine: 427
Axle/Gears: 3:42
I will be getting back into a third gen. here soon. Considering installing a d1sc when I get the car. This thread is very helpful. Thanks
Old Apr 21, 2014 | 05:12 PM
  #69
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
still have not done this yet, but soon... question came to mind, can you remove the belt now with the automatic tensioner? i always seem to have to unbolt the head unit.
ah $hit, i got the 89048 tensioner, i have to mount it the opposite way...
Old Apr 23, 2014 | 05:53 PM
  #70
Tony89GTA's Avatar
Car: 89 GTA
Depends, with my 4" pulley the belt is to tight to slip over but with the 3.4" it's no problem. I can't remember if the 3.7" one is or not.
That part number comes up as a pulley for me. If you do have something that swings other other way the reason I picked up the tensioner I did was so I can get the tensioner pulley closer to the blower pulley and I believe it is easier to get access to for a bar/ratchet.
Old Apr 24, 2014 | 08:11 AM
  #71
86Z's Avatar
86Z
Car: 1986 Camaro SC
yeah, this tensioner is opposite the one you have, i want it closer to the blower pulley, i'm running a 4.0 also, i could not find anyone with the dayco tensioner, so i ordered the gates one instead that is supposed to be the dayco 89401 type, should be here friday.
Old Apr 24, 2014 | 01:06 PM
  #72
Tony89GTA's Avatar
Car: 89 GTA
My gates tensioner never worked out so well, it would twist just that little bit and walk the belt off. The dayco has a really solid design with the big plastic bushing between the two halves, there is no way for it to twist unless the big nut thing came loose. Just something to think about, hate to see you waste your time and money if it didn't work out.
Old Apr 24, 2014 | 04:00 PM
  #73
86Z's Avatar
86Z
Car: 1986 Camaro SC
hmmm, i'll have to check it out when it comes, i can return it if need be, i cannot find a dayco 89401 anywhere under 200 dollars...
i guess i can just use the existing dayco the other way but was hoping for more belt wrap
Old Apr 25, 2014 | 08:51 AM
  #74
86Z's Avatar
86Z
Car: 1986 Camaro SC
ok, i did some research, looks like the 89401 was replaced with the 89429.
i ordered that one up, i'll send the gates one back.
Old May 3, 2014 | 07:37 AM
  #75
86Z's Avatar
86Z
Car: 1986 Camaro SC
got the 89429 tensioner, it will work! had a late night in the garage. got the bracket drilled, need to get a mounting bolt and nut for the tensioner.
it looks like i need to space out the pulley from the tensioner closer to the main bracket. i believe from earlier post you did this Tony.
i raised mine up a bit more than what you have pictured, my concern also about the spring on the bottom of the tensioner hitting the belt.
also the main bracket bolt thats goes through the alternator is a tad proud of the bracket face, looks like i will have to file down the tensioner housing in a small spot to sit flat.
and for the final test of all, figuring out the upper coolant hose to make sure it doesn't interfere..
Old May 3, 2014 | 08:09 PM
  #76
Tony89GTA's Avatar
Car: 89 GTA
Yes I used a washer to space it out some but make sure to use some locktite on the bolt so it doesn't come loose.
As for the spring on the bottom I just rotated it enough so if the belt came loose for some reason it would rub the main housing of the tensioner.
For the alternator bolt I gound down the face of it and it works fine, that way you don't have to mess with the tensioner housing.
The upper rad hose I cut off that plastic part sticking out from the upper rad bracket and then cut the end of the hose some that connects into the rad. A simple zip tie to hold it in and worked fine like that for me for years and years. I'm sure the 8 rib guys don't have as much trouble with this part.
Old May 4, 2014 | 08:28 AM
  #77
86Z's Avatar
86Z
Car: 1986 Camaro SC
there is no way i can space out this pulley enough... i think i need to use the pulley that you did, even for the 8 rib... the current one is way to far from the main bracket and does not sit on the belt all the way....
i ordered up the pulley also... did you use the original bolt for the new idler pulley?
Old May 6, 2014 | 06:04 PM
  #78
Tony89GTA's Avatar
Car: 89 GTA
Yes I did with a fairly thick washer though you could make your own bolt and sleeve setup that would make it fit perfect, just need a lathe lol.
Old May 8, 2014 | 06:32 PM
  #79
86Z's Avatar
86Z
Car: 1986 Camaro SC
alright, i got the tensioner in and working, my biggest concern was the spring tang on the tensioner, i used the original idler bolt hole for the tensioner. i definitely needed the pulley you had listed Tony even with spacers with the 8 rib setup. still need to take it for a test drive..
Old May 12, 2014 | 10:03 AM
  #80
Car: 88 GTA, 74 T/A
One thing I've noticed after installing the spring tensioner is that I have alot a belt dust on the bottom side of my hood. Both from the my regular acc. belt and blower belt. Anyone else experience this?
Old May 13, 2014 | 05:47 AM
  #81
86Z's Avatar
86Z
Car: 1986 Camaro SC
have not driven the car but once, so i cannot help with the belt dust..
the tensioner does work, i need a bigger blower pulley now, i just pulled 15# in 2nd gear and let off the gas, typically before it would only do about 10# and 14 in 4th...
Old May 13, 2014 | 06:17 AM
  #82
Tony89GTA's Avatar
Car: 89 GTA
I get nothing on from my regular accessories belt but there is dust from the blower pulley. I did go to the lowest size pulley and I'm trying out a new 12 rib belt from dayco that seams a little different so who knows.
Glad to see its working for you 86Z! Post up a pic or two of your setup, I like to see what it looks like when you use the original idler pulley hole, I wanted to try it on mine but I had few to many holes already from past experiments that didn't make it align very well.
Old May 21, 2014 | 07:21 AM
  #83
86Z's Avatar
86Z
Car: 1986 Camaro SC
hey, i didn't forget, i've been having other issues, i broke an intake valve spring, have to change all the springs out..
now that i have good tension i'm wondering what to do, 15# in 2nd gear would be a lot more in 4th, i'm thinking that's too much boost for my stock bottom
Old Jun 16, 2014 | 08:10 AM
  #84
86Z's Avatar
86Z
Car: 1986 Camaro SC
well i took the auto tensioner off, i'm tired of playing with it, with the 4.0 pulley it made way too much boost, when i installed a larger pulley with the longer belt, the belt would come in to contact with the spring on the tensioner, and i don't feel like pulling the bracket off again for re drilling.
if anyone is interested in the tensioner with the wider pulley let me know, i will sell.
Old Jun 16, 2014 | 08:23 AM
  #85
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
How much?
Old Jun 16, 2014 | 09:04 AM
  #86
86Z's Avatar
86Z
Car: 1986 Camaro SC
Originally Posted by no new tires
How much?
ill do 110.00 shipped depending on where you are located.
Old Jun 16, 2014 | 05:11 PM
  #87
Car: 88 IROC-Z
Is it just the tensioner the bracket and tensioner?
Old Jun 16, 2014 | 05:38 PM
  #88
86Z's Avatar
86Z
Car: 1986 Camaro SC
just the tensioner with the wider pulley.
Old Jun 20, 2014 | 07:43 AM
  #89
Tony89GTA's Avatar
Car: 89 GTA
Think if you readjusted the tensioner you would be all good but if your using that big of a pulley I don't think you have many problems with belt slip anyways.
Also I'm still using my stock bottom end too, and so far it's lasted I think lol.
Old Jun 20, 2014 | 11:57 AM
  #90
Engine: LS3
Still have the pulley?
Old Jun 20, 2014 | 12:12 PM
  #91
Engine: LS3
I found both the 89401 and the 89429.
http://www.rakuten.com/pr/product.as...ngId=340464282
They seem to have everything. I don't want to buy anything though if someone is trying to get rid of their setup. Prices on that strange site look good too.
Old Aug 8, 2014 | 03:39 PM
  #92
Car: 88 GTA, 74 T/A
UPDATE: I think I figured out why I have all the belt dust. During normal driving conditions the tensioner pulley and the idler pulley have enough clearance, but under WOT condition the belt stretches causing the spring tensioner pulley and idler pulley to come in contract (belt to belt). I dont know if moving the spring tensioner farther up on the mount would help or possibly get the next size smaller (length) for the blower belt.
Attached Thumbnails Procharger guys need a spring tensioner, video and tensioner setup inside!-procharger-spring-tensioner.jpg
Old Aug 14, 2014 | 12:55 AM
  #93
Tony89GTA's Avatar
Car: 89 GTA
I actually removed my idler pulley from the system but kept the same length belt. What size belt are you using for your 3.7" pulley?
Old Aug 26, 2014 | 08:26 PM
  #94
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Any reason why this same belt tensioner wouldn't work on a vortech blower setup?
Old Aug 26, 2014 | 08:50 PM
  #95
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Love all this blower talk
Old Sep 10, 2014 | 03:34 PM
  #96
Car: 88 GTA, 74 T/A
I cant remove my idler pulley, Ive got a custom strut rod bracket that the belt will hit. See attached pic.
Attached Thumbnails Procharger guys need a spring tensioner, video and tensioner setup inside!-mount-pleasant-20120307-00206.jpg   Procharger guys need a spring tensioner, video and tensioner setup inside!-img_20140816_120013_716.jpg
Old Apr 27, 2016 | 06:52 AM
  #97
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Do you have any more pictures of that bracket you made? Also, is there any possibility of too much tension with one of these spring loaded tensioners installed in the wrong position or will they adjust themselves to the correct tension?
Old Apr 27, 2016 | 07:47 AM
  #98
Car: 88 GTA, 74 T/A
I didn't make the support bracket/strut setup, Larry at ASSC over in Chicago actually made it. There are actually two brackets (upper & lower).
1. 5/8 diameter strut rod (upper) - supports the head unit, bolts to header bolt in picture #5, supports the head unit in picture #1
2. Lower support rod - supports the bottom of the procharger bracket from flexing, support rod bolts back to the block.
Hope this helps.
Attached Thumbnails Procharger guys need a spring tensioner, video and tensioner setup inside!-mount-pleasant-20111206-00079.jpg   Procharger guys need a spring tensioner, video and tensioner setup inside!-mount-pleasant-20111206-00081.jpg   Procharger guys need a spring tensioner, video and tensioner setup inside!-mount-pleasant-20111206-00083.jpg   Procharger guys need a spring tensioner, video and tensioner setup inside!-mount-pleasant-20111206-00085.jpg   Procharger guys need a spring tensioner, video and tensioner setup inside!-img_20140526_162610_997.jpg
Old Apr 27, 2016 | 08:05 AM
  #99
Car: 88 GTA, 74 T/A
With regard to the spring tensioner location, you want to make sure you have it positioned so that tensioner can move in both directions. They do "adjust" themselves (meaning you won't have too much tension on the belt), but you want to make the tensioner will compensate for belt flex under WOT (wide open throttle). The manual tensioner that comes from procharger is "OK" if you are only going to run 7 to 8 pounds of boost. Anything more than that (in my experiences) the belt starts to slip and you have belt dust all over the place. I've found that 13 to 14 is about the limit on a 8 rib belt. I've gone as high as 18 to 19 pounds of boost, but the belt starts to slip again. My next step is to switch everything over to a 12 rib set up hopefully I can run 20 pounds of boost with no belt slip. With the electric fan set up that I run I don't have enough room to go to a cog belt set up.
Attached Thumbnails Procharger guys need a spring tensioner, video and tensioner setup inside!-img_20140925_181838_486.jpg
Old Apr 27, 2016 | 05:32 PM
  #100
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks, the pictures were a big help. I just wonder if the brace that uses a header bolt will have enough clearance for my headers (dyno dons). The bottom one should work fine though if he would be willing to sell just that one. They were the first set of pictures ive seen of those braces actually installed.
