ZZ3 Turbo Iroc - Round Three
Old Sep 1, 2015 | 01:52 PM
  #951
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: ZZ3 Turbo Iroc - Round Three
Originally Posted by project89
why not take the tpi off , and put it in a box somewere so u can put it back on if u sell the car , and pick up an hsr or one of the cheap ching chong hsr's ( if they are available again yet that is )
i bet that change alone would be the power ur looking for and widen the powerband of the motor more then enough that u could get a converter to work properly
freakshow performance makes some nice converters and they are priced very well , few members here run them , and i regret getting an fti over a freakshow myself
i'm running a freakshow.
works as advertised.
-- Joe
Old Sep 1, 2015 | 05:35 PM
  #952
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Those converters have built in ballon plates?
Old Sep 1, 2015 | 07:11 PM
  #953
project89's Avatar
he builds them with just about any option u could want
Old Sep 1, 2015 | 07:57 PM
  #954
Big, White & Sl's Avatar
Car: 86 Camaro
Engine: 355
Transmission: Powerglide w/brake
Axle/Gears: Currie 9" w/4.56
Wow! Atmore's a long drive. Too bad about breakaway
Old Sep 1, 2015 | 11:08 PM
  #955
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
gone
Old Sep 1, 2015 | 11:15 PM
  #956
project89's Avatar
Originally Posted by ZZ3Astro
Because I'm tired of a bunch of little annoyances with the gen 1/megasquirt combo. Not the least of which are the long plug wires which always seem to find a way to get against something hot at the most inopportune time. I don't want to spend $500 to get a little bit or improvement on power but still have all of the other issues reminding me that I have yet again wasted time and money. An intake begets a converter. And so on.
I've had it with this setup and the only way this car stays in my fleet is with a completely different powertrain. I've fought it for years and it keeps punishing me in a hundred ways.
That is why not.
Steve
steve give marty a pm on here or the turboforums , he had that twin turbo tpi well into the 9's and i think it even cracked an 8 second timeslip
he ran an holley commander ecu but im sure he could help u get urs all sorted out
Old Sep 2, 2015 | 06:53 AM
  #957
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I've had it with this setup and the only way this car stays in my fleet is with a completely different powertrain. I've fought it for years and it keeps punishing me in a hundred ways...
Go for it Steve. I have been building my 4.2 Vortec whenever time provides for the last few months, and will also abandon the SBC engine in the GTA in favor of it, eventually. Tired of looking at TPI's myself. Do something different, just have fun, no need for headaches...
Old Sep 2, 2015 | 06:54 AM
  #958
-- Joe
Might give them a try soon, cuz TCI is garbage...
Old Sep 2, 2015 | 09:01 AM
  #959
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah he welds the big triangle style plate on.
His converters are balanced, painted an ugly john deere green, and his welds are kinda ugly but they do stall the way he says and a lot of guys on yellowbullet are running fast ET's with them.
-- Joe
Old Sep 2, 2015 | 06:43 PM
  #960
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Sep 3, 2015 | 07:28 AM
  #961
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
-- Joe
how much they run? $$
Old Sep 3, 2015 | 08:12 AM
  #962
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My 9.5", with anti ballooning plate, 2800 stall (@550hp) for TH350, non lockup was $250 shipped.
Basically the same as this one:
http://www.ebay.com/itm/271957446733
-- Joe
Old Sep 3, 2015 | 08:23 AM
  #963
DIGGLER's Avatar
I dont see you getting much of a converter for $250. Especially if you have a car that will need a balloon plate on the converter. I had a $350 jw converter. I bent most all the fins backwards inside.
Old Sep 3, 2015 | 08:36 AM
  #964
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I am looking for 2400 ish stall lockup and balloon plate for my turbo 305 build but trying to do it as cheap as possible
Old Sep 3, 2015 | 08:51 AM
  #965
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why not? It cost about $12 to make a converter.
-- Joe
Old Sep 3, 2015 | 08:52 AM
  #966
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Lockup will cost more simply because more components.
-- Joe
Old Sep 3, 2015 | 11:41 AM
  #967
project89's Avatar
250 is for his base converters so the price goes up with each option but his pricing is really good , lots of ppl on yellow bullet running them and they love the converters
Old Sep 3, 2015 | 01:34 PM
  #968
DIGGLER's Avatar
-- Joe
everyone else is just overly expensive? I think I paid over 300 just getting mine restalled?
Old Sep 3, 2015 | 01:41 PM
  #969
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah it doesnt cost just 12$ lmao. Come on. Restall is labor and rewelding. I paid 300 as well.
But converter itself was 900. I dont think a high quality unit is going to be super cheap.
For 400-600 hp typical street cars yeah you dont need a 900$ unit. 350-500 seems appropriate. I always felt yank/precision were always overpriced for mild street cars
Old Sep 3, 2015 | 01:55 PM
  #970
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The cost per unit to stamp converters and weld them is not very high. They are welded on a machine.
To restall a converter requires cutting it open, chaning or altering fins, and re-welding. That's a different story.
Look at the chinese 1 3/4" long tube headers for fbody now. What are they, under $300? The American headers are what, $1200?
-- Joe
Old Sep 3, 2015 | 03:25 PM
  #971
DIGGLER's Avatar
-- Joe
Are the freakshow converters chinese?
Old Sep 3, 2015 | 03:37 PM
  #972
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I don't know where the halves are stamped but the dude is from Texas.
https://www.facebook.com/pages/Freak...639532?fref=ts
-- Joe
Old Sep 3, 2015 | 04:54 PM
  #973
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Build a nice healthy LM7. You can get a complete pull-out for a grand or less depending on mileage and year engine. I think hot rod did a turbo build for 2k or something.. Cheep ebay turbo. Believe they got 700hp at 14psi or something. read it a while ago. That wont last long.. But a nice healthy one will last and is affordable imo. Next year I hope to do one. Not sure about turbo tho they say that stock cam is perfect for a turbo.
Old Sep 4, 2015 | 02:09 PM
  #974
Yes PTC built for my car. Comes with a free re-stall but they said to do what I wanted to do it needed to be a $900 non lockup converter. I said forget it. Not going non-lockup, that is insane for a car that I drive (drove) on day trips so much - especially in the Florida heat...
Actually, it's not insane. I spoke with Dusty the owner of PTC plenty of times regarding a change from my current TCI converter, and he was trying to sell me on the idea of a non-lockup converter as well. Some guy I used to hang with runs one of Dusty's (PTC) non lockup converters in his daily driver GN making close to five hundred to the wheels, no issues whatsoever with his 200R4 in ninety degree weather as per the tranny temp gauge. I myself am not too crazy about the overall 'feel' of a non-lockup converter, but it won't overheat...
Old Sep 4, 2015 | 02:17 PM
  #975
I dont see you getting much of a converter for $250...
Depends. If your running a 27-spline transmission, then there is no beating a used but good D5 converter, can get them for very cheap, and are very strong for what they are. Those converters are the only reason I would even consider a Turbo 350 or 200R4...
Old Sep 4, 2015 | 03:19 PM
  #976
83 Crossfire TA's Avatar
On a driver it depends on how it acts part throttle and what the gearing is like. Like with my current setup it would be next to impossible to do without a lockup. 3.50 gears (I'll probably end up dropping that to 3.25 or 3.00), the car literally idles around fine at 1100rpm, even climbing hills (right now it has a stick in it, but I'm probably eventually putting the 4L80e in my garage i it) and it would really need roughly a 4000 rpm stall to run it's fastest times.
Some of the better converters out there are quite decent (tight) at part throttle, but nothing that stalls over 4K will be happy cruising around >2000rpm.
Old Sep 4, 2015 | 03:54 PM
  #977
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I run a freakshow converter. Yes on the balloon plate. I like the converter. The slip is pretty good at the top end of the track. 6-8% not to bad for a lower cost converter. Stalls just like they said it would, Absolutely no complaints here. My converter was 320 bucks IIRC(a 9 1/2 for a th350). And they would restal it for free within a year of purchase.
http://www.ebay.com/itm/GM-350-TH350-TH400-Powerglide-Stall-3500-Torque-Converter-9-5-/281773432241?hash=item419b015db1&vxp=mtr
Old Sep 4, 2015 | 10:11 PM
  #978
DIGGLER's Avatar
GM 350 TH350 TH400 Powerglide Stall 3500 Torque Converter 9 5 | eBay
How fast is your car running?
Old Sep 4, 2015 | 10:13 PM
  #979
project89's Avatar
he just went 11:50's at 120mph , hes out of injector as well
he needs to do a cage and injectors over the winter
Old Sep 4, 2015 | 10:22 PM
  #980
DIGGLER's Avatar
Im wondering how fast people have gone with the cheap converters..... I have broken one, but it wasnt a freakshow. Think I went 6.20s or so before it died. ~mid-high 9s in the 1/4. Not very many passes on it.
Old Sep 4, 2015 | 10:24 PM
  #981
project89's Avatar
hes been running his all year hes also hitting it with a 50 shot right off the line to spool his turbo
there prolly just fine for 9/10/11 or slower cars
i know a few guys on yellowbulit run them with some high hp stuff, i have yet to hear anything bad on a freakshow converter, theres a pretty big thread on yb.com about them in the racing section
Old Sep 5, 2015 | 06:22 AM
  #982
fasteddi's Avatar
Car: 1991 Camaro RS
Yea like dave said I went 11.50s and constant 11.60s-11.70s (7.40-7.50 1/8)for the last 20 passes or so when the weather good. For a 400-600 hp car... I feel freakshow is a solid converter. A friend at the track runs 11.50 all day and 10.80s on n20 with a freakshow 4500 stall. He's ran it for a few years now. He is the reason i looked into them. Now if we are talking 9 or sub 9 second cars yea you would probly want a better quality converter.
Old Sep 23, 2015 | 11:15 AM
  #983
ZZ3Astro's Avatar
Car: 87 Iroc
gone
Old Sep 23, 2015 | 01:34 PM
  #984
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Did you end up selling the car?
Old Sep 23, 2015 | 02:36 PM
  #985
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats incorrect statement. There is nothing special about lockup converters at cruise. It helps mileage but as long as there is a trans cooler of some type which alllll auto trans should have, there is no issue with overheating. I can cruise all day long with my 4500 stall. Thats why a 900$ converter costs as much as they do. They have driveability plus stall where they should for the combo. Same with my 3200 and 3600's i had in 700r4/4l60 deals. They dont slip 3600 rpm the entire time lol
Azrael91966669
25
Jun 20, 2017 04:04 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
ezobens
Aug 19, 2015 10:29 PM
mustangman65_79
Aug 11, 2015 03:17 PM
