Pro Comp Alum Heads BBC
Old Aug 27, 2013 | 06:02 PM
cdawg's Avatar
So... i've got a friend that keeps drilling me into trying to buy a set of pro comp alum heads.... they are 800 new for the pair complete.
i've asked a few local people that they are garbage you would have better luck with a good set of cast heads.
well here is my plans.
high compression 9.1 - 12.1 depending on what head and compression i go with...
dome pistons / forge, 6.353 rods / H beams. / stock crank. refresh bottom end with high vol oil pump.
1000CFM Quick Fuel e-85 carb.
i may shoot it with nitrous if i cant get that 12 second mark....but i should with those goals.
Old Aug 27, 2013 | 06:27 PM
project89's Avatar
Re: Pro Comp Alum Heads BBC
they arent that bad if u get new stock, the problem with them is most of the the time they are assembled with pure junk valves and springs.
best bet is to buy a bare set and get ur own valves springs locks retianers studs etc
Old Aug 27, 2013 | 08:06 PM
Drac0nic's Avatar
Um if you cant manage 12s with a bbc with ported big ovals on motor you have issues. Car craft did an article about a 454 with tame compression and lightly worked peanut ports that still made 440hp at the flywheel. Jmo way over complicating it if you have a decent set of heads. If you spray shoot for single digits.
Old Aug 27, 2013 | 08:25 PM
cdawg's Avatar
well, at the moment i have peanut ports. i wanted to step away from them, want to make more power. i keep getting told changing the heads will make a major difference with the build.
Old Aug 27, 2013 | 10:28 PM
Drac0nic's Avatar
Yeah, find some big ovals. If you use the peanut ports even a stocker intake is better than the edelbrock peanut port intake from what i have read, and you can supposedly stick a big oval intake on.
Old Aug 28, 2013 | 08:15 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
My only real problem with procomp heads is their flow number suck for the size of their ports.
Reddeath210
Oct 6, 2015 08:20 AM
Ducati900ss
Sep 2, 2015 09:05 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
mz92274
Aug 25, 2015 08:47 AM
