N20 bottle question?
Old Sep 30, 2013 | 02:24 PM
Ronny's Avatar
I am adding a pressure gauge to my existing bottle that is maybe 50-70% full.
What pressure should I see on a newly filled bottle and when does one refill. Maybe 150 psi?
Old Sep 30, 2013 | 02:45 PM
Cosmik Debris's Avatar
Re: N20 bottle question?
It depends on the temperature but somewhere around 900 psi. The pressure actually stays fairly constant as the bottle empties. The best way to see how full it is is to weight it.
Old Sep 30, 2013 | 04:01 PM
Ronny's Avatar
Would full bottle read 1500 psi?
Old Sep 30, 2013 | 04:04 PM
not unless it was very hot.
Old Oct 1, 2013 | 05:38 PM
Drac0nic's Avatar
The actual pressure is dependent on the liquid temperature rather than the volume. The link below has an awesome table that shows the relationship between nitrous pressure and temperature of the liquid in the bottle.
http://nitroussupply.com/bottletemp.php
Boiling is actually a cooling action, and because of this as you vent more liquid from the tank the cooler it gets ultimately. This is why people have blankets and heaters, to help maintain a constant temperature and in turn a constant nitrous pressure with multiple passes.
Your best bet is a scale of some kind. If you look at the tank it should have a "TW" reading on it. This means Tare Weight, or the weight of the bottle empty. If you throw it on a scale (If you can find the right kind I've seen fish scales used this way) you should be able to figure out the weight of nitrous left in the bottle. Here's a link to a scale that would probably work pretty good when you figured out a way to hold the bottle. Maybe a large cloth grocery bag you could put it in, or some other sling? This is about $25, you would throw your bag on there, hit the tare button to zero it out, then throw the nitrous bottle in it, subract the "TW" number from your reading and that's the nitrous you have left. Unless they have some kind of meter system that I'm unaware of this should be how you buy nitrous too, the guy sticks it on a scale of some kind, fills the bottle until it hits the desired weight.
http://www.oldwillknottscales.com/je...FUWd4Aod6R8AIQ
fasteddi
Sep 2, 2015 10:29 AM
Fox118
Sep 1, 2015 04:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
