Nitrous On/Off
Old Nov 20, 2013 | 06:10 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
Nitrous On/Off
Hey gang,
I am almost done with my nitrous install and what I am curious about is how the 2 stage RPM activated switch ties in with the WOT switch. I was thinking that the 2 stage switch makes the WOT switch active at like 3000 rpm's and once the throttle is wide open the micro switch then activates the nitrous and if it gets close to Rev limiter it shuts off the WOT? Am I correct in that assumption? Or does the 2 stage on portion activate the WOT switch and the Off portion of the 2 Stage get wired to the nitrous solenoid so that it shuts the nitrous off close to rev limter? Just wondering whats the best/right way to incorporate them.
Thanks for the help.
Old Nov 20, 2013 | 07:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Nitrous On/Off
Thats a window switch i believe you are referring to. Wot switch on tb ties into window switch. Nitrous comes on when low rpm level is hit and wot. Once rpm goes above the high rpm level, window switch opens and nitrous is deactivated. Its a safety device so you dont spray when hitting the limiter like missed shift or driveshaft failure
Old Nov 20, 2013 | 07:31 PM
Slayze's Avatar
Car: 87 Trans Am
Re: Nitrous On/Off
This is the RPM switch I was referring to http://www.msdignition.com/Products/...ed_Switch.aspx
Old Nov 20, 2013 | 07:34 PM
Slayze's Avatar
Car: 87 Trans Am
Re: Nitrous On/Off
So what your saying is that I hook the RPM switch (or Window Switch ) to the WOT Switch and thats the correct way? Thanks for the reply.
Old Nov 20, 2013 | 07:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Nitrous On/Off
Yeah use it with the ground activation wire feature. Master arm power to wot switch and wot switch to solenoids. Solenoids ground to window switch
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
