Twin Turbo Advice Needed
Old Feb 26, 2014 | 10:24 AM
Anthony Franz's Avatar
Car: Black 1991 Pontiac Trans Am GTA
Engine: 350 5.7L V8
Transmission: Monster Trans 700r4
Alright so im putting a twin turbo kit on my 91 gta with a 350 tpi. I was wondering what to do as far as internals in my engine. I want to know if a forged steel crank will last or if I need something stronger. I want to push about 14 to 16 lbs of boost total. I think as far as rings, pushrods, valves, valve springs Im going to put in titanium. Also are forged pistons and rods good enough? If I wanted to push full boost which is 27 lbs what would be the best internal setup to achieve proficiency ?
Old Feb 26, 2014 | 12:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Twin Turbo Advice Needed
This is impossible to answer because no particular detail was given regarding application and usage, rpm and power goals, etc
Where did the boost numbers come from? What about 14-16 lbs or 27 lbs is special?
Everything will be determined based on a set hp and rpm goal. From there the system can be spec'd out and parts selected
Terrell351
Jun 13, 2021 01:13 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
