86 Ta 383 s475 build
Old 10-11-2016, 09:39 AM
  #101
boosted chicken's Avatar
Car: 1984 transam
Engine: 406 sbc
Transmission: Turbo 400
Axle/Gears: Moser 9 inch
Re: 86 Ta 383 s475 build
Gotcha very nice how about ur ground clearence on the down pipe? I ask becucause im thinking of mounting my turbo in the area were the coolant tank was and running my up the way u ran ur down pipe. My turbo would face the same way as urs. And down pipe would go str8 out the fender.ive already trimmed the wheel wells and test fit it the turbo would fit there.
Old 10-11-2016, 10:03 AM
  #102
86trbota's Avatar
Car: 86 trans am
Engine: 383 dart 215 billet 84mm s400
Transmission: th400
Axle/Gears: 3.08
No ground clearence problems on the down pipe. Should be plenty of room to put a couple 2.5" pipes up there. Sounds like a cool build man.
Old 10-11-2016, 11:10 AM
  #103
Car: 1984 transam
Engine: 406 sbc
How ur ground clearance with the dp. I was thinking of running my up pipes that way and, mounting the turbo facing the same way u do but were the coolant tank used to b
Old 10-11-2016, 11:11 AM
  #104
Car: 1984 transam
Engine: 406 sbc
Never mind slow phone said my first post didnt post sorry
Old 10-11-2016, 11:12 AM
  #105
Car: 1984 transam
Engine: 406 sbc
Ty im jist running fender dumps for now so i can mock up and keep drivinf the car for now
Old 10-12-2016, 10:22 PM
  #106
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
Been pretty much done with the car for a couple months now. Been driving it alot lately getting the bugs worked out of it. I had some problems with the motor, had to replace all 8 intake valves. The valve lash would close up on the intakes after about 50 miles of street driving. I backed them off once and readjusted but they were closing up again so I tore it down. Got that fixed and all is well after that. I had the boost set at 10 lbs for awhile on pump gas with no meth till I got the carb dialed in. I turned it up to 15 lbs with the meth kit and that really woke it up. My speedo doesn't work so I have a gps app on my phone and it will burn the tires from a 60 roll on the highway easy. The 84mm wheel makes a ton more power than the 75 did. Im gonna get some drag radials for the back and try to get to the track before it closes in november. I'm hoping for some 9 sec slips on 15 lbs and pumpgas/meth. This winter I'm gonna get some drag wheels and tires and turn it up some more. Here's some pics of the interior all done except the headliner still need to get that finished up. Pretty happy with the way it turned out and how it's running.
Old 10-12-2016, 10:29 PM
  #107
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
One of the intake valves all Tuliped
All back together
Some interior pics
Old 10-12-2016, 10:33 PM
  #108
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
Got the hurst shifter mounted in the stock console.
Old 10-12-2016, 10:37 PM
  #109
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
All washed up
Outside the shop for the first time in awhile
Old 10-13-2016, 08:47 AM
  #110
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Looks great man!
Jay
Old 10-13-2016, 01:37 PM
  #111
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
Thanks jay. What made you want to swap a six speed in your car?
I decided to get some champion wheels this winter. Gonna get some 15×10s not sure on the backspace yet. Mr rear is narrowed 1" on each side so I'm gonna measure some up. Tossing around the idea of mini tubbing it to get a 295 on the back and still tuck and sit lower.
Old 10-13-2016, 02:46 PM
  #112
Car: 1984 transam
Engine: 406 sbc
Very nice work bro. Good to c someone staying with the gen 1 blocks also and not just turboing an ls. Nothing against ls just cool to c it done the same way i want to.
Old 10-13-2016, 02:48 PM
  #113
Car: 1984 transam
Engine: 406 sbc
And as far as the rear ends go. I ordered a moser with 4 gen brakes but i think they sent me a 4th gen rear. Cuz i have a 6.5 bs and still poke. But its not terrible so im ok with it.
Old 10-13-2016, 03:05 PM
  #114
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
Thanks man. Ls swaps are cool but I already had all the Gen 1 parts and I know them like the back of my hand. I'm definantly gonna be pushing the limits of the block but lots of guys have gone fast with stock block sbc stuff and I hope to be one of them. I'm gonna keep the tune on the conservative side and not push the timing to much. I plan to turn the boost up to 25+lbs and see what happens, it's either gonna live or not. A dart block build is in my future plans. The 4th gen rears are 1in wider than stock 3rd Gen I think, my rear is 1in shorter on each side than a stock third gen so I don't know where that puts me with backspace without measuring.
Old 10-14-2016, 08:50 AM
  #115
Jay_rich's Avatar
Car: 1987 Z28
Honestly just the fun factor, car has been together and running for 2 years, never have time for the track. Pretty well just drive it to work and to random shows so I wanted the fun back in the car. I know it will be slower and less reliable when at higher HP levels but meh.
Jay
Old 10-05-2018, 01:52 PM
  #116
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
Awesome build nice work, I’ll continue following along
UltRoadWarrior9
04-28-2020 10:39 PM
83RDRACR
03-26-2016 08:13 PM
Jorlain
10-08-2015 01:57 AM
Mongoose462ci
09-16-2015 11:46 PM
Quick Reply: 86 Ta 383 s475 build
