Spark Plugs for Procharged 383 TPI
Old Mar 28, 2014 | 10:42 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am installing a Procharger D1SC onto my 383 that will be running around 10-12 lbs of boost. AFR suggests normally running fr3ls plugs in them as a start but says to go 1 to 2 heat ranges colder for a blower motor. Would I be better off with the FR2LS or FR1LS plugs? Anybody have any experience with these?
Old Mar 28, 2014 | 11:49 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: Spark Plugs for Procharged 383 TPI
In for pics.
Old Mar 30, 2014 | 05:33 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I use autolite 3923 on my engine
Old Mar 31, 2014 | 09:45 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Old Mar 31, 2014 | 09:51 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Whatever brand you use, find what heat range is stock. Built motor high comp, usually step down 1-2. Mild nitrous or mild boost, step down 1 more. Heavy nitrous or boost, step down 1-2 more.
I use ngk. 4-5 heat range is stock. Built na motor you run 6's. mild boost 7's. my heavy booster i run 8's
Old Mar 31, 2014 | 05:32 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
double check with the plug manf. some plug numbers that go low don't mean it's a colder plug but usually start with 2 colder and if the engine doesn't like it step up to the hotter plug
Old May 6, 2014 | 12:12 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
I've been running e3's e3.48 but I can't figure out if this is good plug for a procharged engine . Has anyone found a heat rating for these or had good luck running them supercharged?
Old May 6, 2014 | 12:25 PM
project89's Avatar
another one for the autolite 3923's and there cheap at $1.80 a plug
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
