Dipstick for a single turbo build (Downpipe routed on pass. side)
Old Apr 16, 2014 | 01:31 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I'm sort of at a road block with where and what dipstick to use for my build. I have a single Garrett GT4294 mounted in the battery tray with a 4" down pipe parallel with the drivers side valve cover. I can't get my stock dip stick to work. What have you guys used in this situation?
Old Apr 16, 2014 | 01:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Dipstick for a single turbo build (Downpipe routed on pass. side)
Lokar cable style thats flexible and move around to fit as needed
Old Apr 16, 2014 | 03:45 PM
Car: 91 Firebird
Engine: Turbo 355
The one from Lokar is 15" long. I don't know if that will work. I was going to browse the junkyard and hope to find a vehicle with a longer dipstick I could maybe bend up to work?
Old Apr 16, 2014 | 03:56 PM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Some of the truck dipsticks are pretty long.
Old Apr 16, 2014 | 04:08 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
get a super long one made for a astro van or something. Cut to fit.
Old Apr 21, 2014 | 01:26 AM
bvahnee's Avatar
I built my headers then put the stock dip stick into place. ("into place") I looked where it needed bends and then bent it in a vise, took a few tries but ended up with a dip stick that just fit by the headers. Im guaranteed to have a more complicated setup than you, if I could get it to work you could also.
Dont over think it. If it needs a slight bend, just bend it. Just make sure your level isnt affected greatly
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Cameeeero
Aug 20, 2015 03:06 AM
Leggman1
Aug 6, 2015 04:15 AM
