Boost question about Aeromotive 13301
Old Apr 19, 2014 | 09:18 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
If you set this to 65 psi AND referenced it for boost, would the pressure go higher than 65 psi?
http://www.jegs.com/i/Aeromotive/027/13301/10001/-1
Old Apr 20, 2014 | 09:24 PM
Drac0nic's Avatar
Re: Boost question about Aeromotive 13301
You will get 1 PSI of pressure extra per PSI of boost you have. As a word of advice, you will drop pressure equal to the vacuum the engine pulls as well if referenced against the intake. If you reference against the charge piping you should have a constant base FP until boost comes on. I would probably reference against the manifold, it makes your injectors look smaller which can help idle tuning especially with bigger injectors. It's also the way that the vast majority of OEM EFI setups are set up. A notable exception being TBIs actually.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
