84 H.O. potential street build
Old May 30, 2014 | 07:26 PM
zachariahZ28's Avatar
Car: 1984 camaro Z28 H.O
Engine: 5.0 H.O
Hey everyone I have a 84 Z28 H.O. Vin G, and I'm wanting to have a performanc street car that I can take to work, and have fun on the way it's all bone stock, what would y'alls opinion be on giving her some extra skip? Thanks for reading -Z
Old May 31, 2014 | 07:11 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 84 H.O. potential street build
What's the budget?
-- Joe
Old Jul 15, 2014 | 01:14 PM
Engine: 5.0 H.O
Sorry for the super late respond! Phone didn't have Internet for a good while -.- and well I'm gonna go to the bank and get a loan to build my dream car maybe 3-4,000? I've been thinking of just swapping my original engine for a 383 turn key engine, but for that I would want a new transmission knowing myself, but now I've been thinking about a super charger? which would be easier in the long run (not cheapest)?
Old Jul 16, 2014 | 10:55 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Getting a loan to build a car will get even more expensive than it already is…the only thing you'll get is a high interest personal loan if you manage to get one at all. Not good IMO. Much better to save and do it that way.
Other than that, your car is a blank canvass…so many different things you could do…LSX, Gen1 stroker, turbos, blowers, nitrous etc..
None is worth anything unless you have a car that provides a good solid foundation for the new found power…
Old Jul 16, 2014 | 01:49 PM
Engine: 5.0 H.O
Wow, I totally get you. I guess for now I'll just do little stuff, headers, y pipe, new cat back, maybe new heads along the way? I'm just not too sure on what my foundation should around? Any personal suggestions?
Old Jul 16, 2014 | 07:44 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
5.3 truck motor will give you a nice boost in performance. Price can range from $500-$1,000. Just have to shop around (junkyard, craigslist, the classifieds on here). This will be easier and cheaper for you in the long run. You can almost double your power, better drivability, better mileage, and HUGE power potential. Lots here have done it and there is all kinds of info and tech articles on this swap. And none of them have any regrets about the swap either.
Old Jul 16, 2014 | 11:21 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
On the cheap?, port and polish the heads, port match the Intake, s10 torque converter if applicable, summit 1102 or 1103, and a full exhaust. These parts should run a few hundred dollars and would really help wake up the car. Me personally I would focus more on suspension mods to make a dd more fun to drive. Driving a fast car is fun but having a dd driver that handles like it is on rails is more fun IMO and I own 1 of each type of car.
Old Jul 17, 2014 | 07:46 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Do whatever you want to engine wise. There are a thousand good options. The engine is the least of troubles dealing with these cars.Your suspension should get an overhaul #1. Transmission may need an upgrade. Rear end will eventually need an upgrade.. Then if you gona make it a DD make sure your engine aint to radical and wanting to run hot in heavy traffic. Fast is fun but having a dependable ride is much more enjoyable in the long run. Good luck with your car.
Old Jul 17, 2014 | 12:22 PM
Engine: 5.0 H.O
Are they're any recommended brand? Or should just standard replacement brand do the trick in your opinion?
Old Jul 17, 2014 | 03:17 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Like the other man said a strandard truck engine 5.3 or 5.7 vortec would be a great selection. you can buy a brand new vortec from summit around $2100 slap in a more performance oriented cam with a good carb and headers and have 325+ hp and a relatively easy swap. The newer 5.3 engines have great power but not so easy or cheap to fool with IMO.
86CamaroDan
Sep 29, 2015 10:08 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Street Lethal
Sep 7, 2015 01:09 PM
machinist21
Sep 5, 2015 03:03 PM
