Dual Fan Set Up with Procharger
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
What dual fan set ups is everybody running on here with their procharger systems? My factory ones don't seem like they are going to work.
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: Dual Fan Set Up with Procharger
stock fan + http://www.summitracing.com/parts/prm-19112 infront of my blower bracket.
(no it was not "my" money)
Car: 85 Iroc-Z
I forgot to mention I am running a Be Cool Radiator as well, which takes up more room.
Car: 88 IROC-Z
Car: 92 Camaro RS
Engine: turbo 5.3
Transmission: th400 with 3500 stall
i am using 2 11" Spal Paddle Blade Puller Fans, with a turbo and they seem to be doing great , 100deg outside and the car hit 224 but that was the highest so far
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Car: 85 Iroc-Z
Picture of the set up. I have about 4 1/4" of clearance. The spal fan set up is just about that size.
Car: 88 IROC-Z
Car: 92 Camaro RS
Engine: turbo 5.3
and i thought mine had no room , wow thats pretty good setup you got there, how much power does it lay down? that fan seems to be doing great , if you look around youll find a good deal on some , if you want i can pm you the site
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
I run dual Derale fans. Pullers. Car is appart right now, but I can post a pic of the radiator with the fans mounted if you want.
I am running a BeCool Circle track radiator. Much Much cheaper than a stock replacement. Places the outlet on the other side and converts it to 16-AN. I had always wanted a braided upper radiator hose.
Car: 85 Iroc-Z
I haven't ran this set up at the track yet or on the dyno either. Yeah some pictures would be great. Thanks
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
dual flex-o-lite fans with shroud (3000CFM).
Car: 85 Iroc-Z
I ended up going with the spal fans
Car: 88 IROC-Z
Car: 85 Iroc-Z
Waiting for them to get here. Should be here within the next few days.
Car: 88 GTA, 74 T/A
Car: 85 Iroc-Z
Going down the highway around 180, in town around 20-40mph about 190's. It's just in traffic that it heats up quick.
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
The RamCharger Chrysler dual fans are rated @ 3800-4000 CFM and are pretty powerful. They are wired in series and unlike aftermarket fans allow for a low and high speed. Here's a pic of one of my setups and they fit the entire fin area nearly 100%. The depth is 3.5" so for their size, extremely stout IMO.
ambainb
Apr 25, 2016 09:21 PM
