Bad injector question
Old Aug 15, 2014 | 06:41 PM
jay7199's Avatar
I have some 50lb injectors on my supercharged setup, I been trying to diagnose why its smoking and failed to pass inspection with a 800hc reading at idle
So I was wondering if I could possibly have a leaking fuel injector, I pulled all the plugs and found number 8 looking rough so I put my figuers on all 8 injectors as the car idled, every single injector has a very discernible deep click but number 8 was very soft and weak.
I fear that its stuck open or not opening at all, the car cruises good and pulls good but iv had this problem since installing the supercharger about 300 miles ago so I dont know if its been missing power all along or what.
Here is a pic of # 8 compaired to number 4
Old Aug 16, 2014 | 03:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Bad injector question
The # 8 plug looks more oil fouled then fuel fouled. Which in turn caused a misfire that then showed up as high HC's.
Best case is a bad intake valve stem seal, possible intake manifold leak at that runner, or PCV (depends upon where it is fed into the manifold).
Worst case is a broken ring(s) or piston on that cylinder.
RBob.
Old Aug 16, 2014 | 04:21 PM
jay7199's Avatar
yeah I know it looks oil fouled, but something is clearly going on with my injector. I want to figure out the injector, then go and see whats up with the oil. I just replaced the valve stem seal and put some marvel mystery oil in the cylinder increase a oil ring was stuck. then I want to start it and noticed the injector.
Old Aug 16, 2014 | 04:56 PM
jay7199's Avatar
yeah.. something was up with the injector for sure..
Click image for larger version
The other 7 look like this.
Old Aug 17, 2014 | 09:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I've seen that goo on injectors when running E85.
RBob.
Old Aug 17, 2014 | 10:03 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Have you tried ohming all the injectors yet?
Red iroc-z 305
Sep 30, 2015 05:22 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
