bitten by the boost bug
Old Mar 15, 2015 | 07:08 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
I had a 97 eclipse gsx that I built and was a lot of fun. Now I'm trying to focus back on my passion for my 383 powered t/a. Its running around 10:1 or a little more compression on stock rods and crank, hyper pistons with Afr 195 heads, all ARP hard ware and a 750 mighty demon carb. I was thinking of adding a turbo and running 8 to 10 psi. I know I'll have to change carb to a blow through style. I was thinking of a mp gt45 turbo. What would be best and how far could I safely push it and what possible HP could I squeeze out of it. I estimate right now im at 400rwhp NA. Im also trying to limit rpm to about 6k if possible.
Old Mar 15, 2015 | 09:12 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: bitten by the boost bug
I'd start by beefing the bottom end up a bit. I can't see the stock bottom end and hyper pistons for very long. It's also a good opportunity to get new pistons and drop your compression a bit, as 10:1 is a bit high for a pump gas turbo engine
Old Mar 15, 2015 | 10:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
stock rods are gonna hurt it. I wouldnt try more than 450-500 whp. Even thats iffy. And you'll hit that power on a few psi but i'd go vs racing 7875 turbo or gt45 series 75-80mm upgrade
$750 L98
Feb 1, 2025 02:25 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
