Single turbo 352 iroc 1000hp or bust the grand finale
#1151
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: Single turbo 352 iroc 1000hp or bust the grand finale
I gave up on reading the debate, but I noticed resolution was an argument.
If you want more resolution then do what I have been doing for years. Read the 1bar in one 0 to 5v a2d input, and another diesel MAP in another 0 to 5v input. It gives 0 to 10v volt range. The diesel sensor reads 80 kpa to 3 bar. Problem solved.
Find a better diesel sensor than I have and get better resolution.
Yeah, a lot of the coders around here are old school trying to jam 3 bar into 5 volts.
The V6 vs V8 argument on resolution is null.
Some of the guys on other sites have dual MAP sensors, but they are running a 1-bar MAP and then a pressure sensor for secondary fuel load.
With the 3.4.2 firmware, Project89 can pretty much do whatever he wants for fueling.
-- Joe
#1152
Not really getting personal Joe, that would be impossible because I don't know him on a personal level. I only know what has been said on this website both by him, as well as by others. None of what he says is new. Callaway maintained the factory '7165 and switched to a MAP w/calibrated prom for their twin turbo B2K L98's in the late 80's, nothing new there in terms of dropping in a prom and converting MAF to MAP for boost. RBob's EBL Flash is superior to that concept in every way, even Callaway would agree. In the early 2000's the idea for a flag switching from one MAP to another to increase resolution was presented by RBob, and others who were just as open to the ideas and creative genius in the DIY agreed, but nobody did anything with it. RBob did, was done years ago by him.
Also, let's get into recommending that members to run a tube the same size of the stock MAF to increase fueling by doubling injector size and adding resolution? What kind of tech advice is that? Would love to see the air intake routing just prior to the throttle body with that one, especially a boosted setup. Do they even make a silicone fitting for that concoction? Bottom line is he only posts to pat himself on the back, and to bad mouth other systems that "he" won't use because of his personal feelings, so I am not the one getting personal. I think we can all agree that GM purposely used small TPI runners and peanut camshafts in conjunction with 8-bit processors because there was never really a need for a better system to control an already restricted engine, so why would GM need more resolution for a 200 horsepower engine. The system was only designed to control their engines with a little more room to grow, nothing more. Enter OBD2 and soon GM had all the room they would ever need, but again, power never exceeded the threshold from the factory for GM to even need it. We did.
#1153
But all of this doesn't matter, because Project89 isn't using an antique ECM or outdated code. He's using an MS2, and he can do pretty much whatever he wants with it. If he wants dual MAP sensors, he can do it. If he wants a 3 or 4 bar map sensor, he can do that too. Heck, he can even do staged injection if he really wants mess around.
-- Joe
#1154
Originally Posted by project89
its late an i need to be on farm early so ill post up datalogs n stuff tommorow...
Good job Dave, I for one am very inspired, and I know others are too, but might not admit it.
#1155
trans is comming apart , ive either broken the converter or the high gear pack is burning up bumped her to 14 psi added a touch of ignition timing and as soon as i shift to high gear its noses over
fluid still looks good so not sure what ill find
not going to pullt he trans just yet as i need the car for the pioneer days parade on the 23rd , and not sure if i can get parts intime if i tear into it now specially with us starting to harvest the second hay crop today
2nd gear at 6,300 rpm shows 70-71% dc @ 12.0-1 afr @ 14 psi
head/cam intake combo love rpm , wish i had a more stout bottom end and cam to see what it would do at about 7200 rpm
#1156
i just had a thought maybe i should try turning the boost back to 5 psi and see what it does in high gear
if its burnt up i may just fix it/sell it and go grab an 4l80 with a manual vb, though if i have to change transmissions a t56 would be really nice but then im looking at all sorts of upgrades for that to live behind the motor as well
#1160
i would but a 400 isnt easy to come by were i live , 80e would be much easier to get my hands on, though i guess if i repaired the th350 if it is burning up i could prolly trade it off for a stock th400
my one friend has a 4l80 out of a gm diesel , those ones dont need an ecm to run , the hard part would be getting him to part with it as they were only made for 1 or 2 years and are hard to come by
#1161
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Orr can you expand on that 80e thought process a bit? I'm planning to use my 80e on the iroc at some point. I want to run 1/2 mile events so I really need the 4th. Just curious what you have in mind 80e vs 400.
#1162
im in the same boat as u pretty much with boneville so close to me i plan on doing some lsr and that od would be handy to have and a 80e would be cheaper then a 400 with a gear vendors unit on the back
#1163
I have a TH400 in one of my Vettes. It's not a bad trans, but I've been using 4l80e, 6l80e, etc for over a decade now and they are a lot nicer. My 2012 has a 6L90e which is a fantastic transmission, and waaaay stronger than a TH400.
For about $260 you can get a transmission controller from diyautotune that will integrate with your MS2 so you can control everything from a single GUI if you wanted to switch between manual and automatic mode.
(plus it would be nice to be able to log VSS)
-- Joe
#1164
#1165
I'm running a 3.45 and a 26" tire and even that is sketchy..
-- Joe
#1166
Originally Posted by anesthes
2.73 and a large tire?? Is this some sort of technique to load the engine to get the turbo to spool faster??
-- Joe
-- Joe
#1167
Used to. Now i have a 12 bolt with 3.42's and will go to 3.08 soon as i can. Trying to get 1000+ hp to work and being able to hit 165+ mph with only 3 gears, you need a highway gear to work
Most guys going fast run th400's. 80e's just dont seem to work well for high hp drag applications. The od is nice for street but a th400 with a 3.08 gear and 28" tire is near the same imo. 80e's are more expensive all around, and only a few builders seem to have their finger on the post with them. Th400's are well known and the top trans builders around have gotten them to work exceptionally well with big power
I also dont think OD gears can hold power, not sure but i know 700/4l60's dont seem to like wot in od gears. If you can make it hold the power then it be nice for top speed runs but you can turn near 200 with 3 spds
1/2 mile events are no problem. Gear to match and run as tall a tire as you can fit. 28" is usually enough. 3.08 gear and 28" tire will go 195 mph at 7500 rpm assuming 4% converter slip so actual 7215 rpm at trans
#1168
Many people are still stuck in that 3.73/4.10 mentality, which is good of course for a short sprint with a naturally aspirated engine, but no match for a boosted setup with tall gear. Joe is also a Corvette guy like me, so he is familiar with the gearing that they run. My old White C4 that I was planning on supercharging came stock with a 2.54 rear gear, and a lot of the Grand National guys I know were suggesting a 3.55 at a minimum, and I told them no way. The 2.54 had a tremendous advantage in my old Corvette, you just needed to maintain RPM throughout, otherwise it will be a dog out of the hole...
#1169
Yeah, turbo's love the additional load to help them spool faster, and the taller gear (lower numerically) will greatly increase trap speed so long as RPM is maintained, and with a faster spooling turbo, it will. This is why it is not uncommon to find 3-speed tranny's like the Turbo 400 easily trapping close to, and even over, 200-mph in the 1/4 mile.
I've never owned anything that would rev to 8500 without also peppering the stands with metal.
I'd imagine something with a 2.73 or 3.08 gear and a tall tire would probably be very laggy on the street. (unless you're launching it leaving every green light like you're at the track). But then again you don't usually see many 8 second race cars on the street.
-- Joe
#1170
On my car, I've got a 6,000 RPM shift, which is 134mph. That is realistically probably slightly faster than my combo can achieve, so it's obviously the right gear + tire combo.
-- Joe
#1171
That is one of the benefits of high stall converters when they are built right with those kinds of setups. The plan with my old Corvette was an F1X running a PTC stall converter from Dusty Bradford with around 3500 stall speed, while keeping the 2.54 rear gear. No lag at all with the supercharger, but the rate of acceleration (if hooking) might have eventually twisted the frame at high boost pressure off the line...
I filmed his scene from street outlaws for him, he is one hell of a nice guy.
... and the guru w/converters.
Most of the fast cars around here use powerglides, but they are spinning 8500 RPM.
-- Joe
-- Joe
#1172
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You mentioned in an earlier thread that one reason for wanting to sell was due to drivability and gas mileage. If you went with the 4l80E you would gain gas mileage. You can also do the ghetto trans lock with it for free.
Check out the 427 ECM that came in trucks. It can control p&h or saturated injectors and the 4l80e/4l60e/th400/th350/700r4. Maybe street can hook up with vanilla and they could do a quick boost code mod to it. You can get these PCMs at the junkyard for 50 bux.
Just a thought. I am sure at least one person will be totally against it. Maybe even post a music video of people dancing while tuning it.
#1173
In either case, both dont apply on my setup. Hotside is sized correctly in conjunction with the converter to provide very fast spool. And 400" of sbc will move anything, even my 3800 lb street deal from a stop sign. Tall gearing is not a hindrance
Street is right, a good converter makes it work these days. I have somewhere near 4500-5500 stall depending what boost level its at. Off idle, it acts more like my old trans am's 3200 stall. Maybe even tighter. Its the best of all worlds.
#1174
Car: 87 Iroc
ok Orr I see what you're saying. I guess with all of these new cars running 6 and 8 speed autos it is hard for me to want to run a 3 speed. At some power level you don't have an option though I guess. I don't expect to be faster than 175 in this car and expect to run a 3.08 rear ratio when I upgrade to a new one. So at 6500 with 4% slip I can just do 169 on a 28" tire. By the time this car can go 175 in the 1/2 it would have to be able to run 150 in the 1/4. By the time I'm running those kinds of numbers I'll have a new bottom end so it will have a few more rpm available.
#1175
-- Joe
#1176
I think after all this time I'm finally starting to understand Joe lol. I have never built a third gen with the intentions of rivaling a newer class of cars, and I finally see that this is what Joe is after. This is the reasoning behind an abundance of features being needed, as well as massive resolution, control and precision. He wants that new car feel from his third gen. Sadly though, ninety percent of the members on this board build their third gens the totally opposite way, they want the grunt. Funny thing is though, from what I read, the third gen was considered to be way more refine and ahead of its' time than all of its' predecessors, as well as its' rivals during that time. But Joe wants to build a 2016 third gen with what's readily available from the aftermarket, to take on a new set of rivals today. If that is the case though, I would lose the SBC and go crate 6.2 LT1...
#1177
I'm the same way with everything I build, you just hear about the thirdgen because I don't discuss my other projects on this forum. (other than a brief mention from time to time).
I did pick up a 5.3 the other day for another project, so yes, I have been thinking about GenIII my friend.
I like technology, I like comfort. I even hot rodded a bobcat I owned a few years ago.
I totally lost my shirt doing a C4 about 10 years ago. You can't really improve those cars without spending 30k, and the end result still isn't that great. That's why I was asking you about your C6.. Was thinking of picking one up. I'd like something that is fast and has a/c.
I think Orr too offense a week or so back when I told him I probably wouldn't enjoy driving his car. It wasn't because I was implying that his car was defective, simply that I'm not interested in that type of build. No doubt it's fast, and probably reliable. But even a 5000 rpm converter would drive me bonkers. I sold Project89 my TH350 reverse manual valve body because I absolutely hated it. Built a regular automagic TH350
-- Joe
#1178
The gear. We discussed the other day that you are not in boost 90% of the time, yes? So I don't think the turbo would be a concern.
Interesting. I have a little more displacement, and I think the same heads as you, so I'd expect our motors to be similar n/a. I'd think my car would be laggy with any less gearing than I have.
Holy crap.. I have like a 2800 stall.
-- Joe
-- Joe
Its def not the same feel as say a ls1 all motor car from a stop or my 6.2 gm truck with the 3.73 gear and 6l90 lol that steep gearing lights up all 4 from a dig
But normal civilian driving, its more than adequate for the street. Its more peppy than my stock 305 car
#1179
ive got 2:73's in mine atm and its no slouch off the line
that 4500 stall fti makes all the difference hell u can see me put it sideways in the one vid turning onto mains street , i couldnt imagine trying to drive it with 3:42's on the street
#1180
i think i know whats up with the th350 right now
what i just found out is the direct clutch pack (3rd gear) is also used when the transbrake is applied , being that im having issues both on the brake and in high gear , im pretty confident now the converter is fine , and i either have to much clearance in the direct pack or the pump isnt supplying enough volume/presure
fluid is still pink so ill keep the car out of high gear for now and ill tear into it after the parade and recheck my pack clearances
#1181
I've been experimenting (on my test bench) hybrid MAF/MAP, to both solve the resolution issue and allow for better tuning control during part throttle. What I'm torn about is what range MAF to use, but I'll expand on that in another thread.
-- Joe
-- Joe
ED:Suckage on the TH-350. The 400s are pretty easy to build up to that power level and would let you re-use your current converter which is a plus.
#1182
That makes a lot of sense, you effectively have a boost table and an off boost table. They make a version of the MPX4250 used in the Megasquirt that would work well for it, the MPX4250D. As an added bonus it should be good for over 30 PSI if you're into cranking stuff up on good fuel. I'd consider such a set up over MAF just because of simplicity in plumbing which is likely going to be a compromise with a MAF setup.
very little of the transmission has to come apart for my issue
#1183
The problem with a MAP system is your ve can change at any given rpm vs map, sometimes dramatically. Make minor changes to the combo, have to re-dial in the entire fuel map. And you typically rely heavily on AE to resolve throttle movement issues.
On a MAF system you are actually measuring the air, so calculating the fuel required is quite simple, and leaves less for the closed loop correction to have to deal with.
But MAF's don't work well with positive pressure, so the hybrid system is a good solution.
GM went back and forth with MAF and MAP, before finally deciding that both were required to live in harmony.
-- Joe
#1184
#1185
ive got 2:73's in mine atm and its no slouch off the line that 4500 stall fti makes all the difference hell u can see me put it sideways in the one vid turning onto mains street , i couldnt imagine trying to drive it with 3:42's on the street
#1186
GM uses a more expensive sensor to save on costs?
You should stick to what you know my friend.
-- Joe
MAF sensors will be obsolete. An ideal factory system is MAP based, Wideband O2 corrected, EGT probed, and ION sensed. GM is aware of these types of systems, but chose not to invest in them. Hell they even went back to pushrods after playing with 32 valve w/multiple cam engines in the 90's, this right here should tell everyone how dedicated GM really is regarding tech...
-- Joe
#1187
Gm hasnt made any positive pressure v8 vehicles until recently. Lt1 and ls1 had maf and map. I am not sure why they felt the need to do both, maybe an emissions thing? Both work well.
My favorite cars to tune are the maf tpi cars except for the datalog bugs in $6e. I just did heads cam intake on a L98, and base chip with just injectors changed and idle command speed set, it started right up. Idled on its own although needed some throttle screw adjustment.
Map is alittle more tricky to dial in. But you can dial in. Just about every ls1 car that comes thru the local shop gets speed density tuned
#1188
#1189
#1190
GM did this to save on cost, not because of harmony. MAF sensors will be obsolete. An ideal factory system is MAP based, Wideband O2 corrected, EGT probed, and ION sensed. GM is aware of these types of systems, but chose not to invest in them. Hell they even went back to pushrods after playing with 32 valve w/multiple cam engines in the 90's, this right here should tell everyone how dedicated GM really is regarding tech...
That said, GM *DID* have a whole line of high volume production DOHC 32V V8 engines in the 90s and early 2000s. Even chopped one down into a V6 ala the 4.3L They axed it for the LS because it was good enough and why pay for it needlessly?
Lastly, because it's not on a US production car doesn't mean GM hasn't both worked with it and isn't planning on using it. Developmental cycles take a long time and as a global company there are tons of things that are produced for overseas markets that never even get seen here.
#1191
Draconic you are missing the point. I already said that GM experimented with 4 valve per cylinder multi camshaft engines in the 90's; LT5, Northstar, or even their six cylinder LQ1, etc, but nothing ever really came of it from a performance perspective, they chose to go back to the pushrod engines, because not only were they more cost efficient for them, it simply worked. They did not invest in the time to pursue other avenues that the other manufacturers were going in until they went global, and even then the pushrods remained, which many in the world view as detrimental. The GM brand does not sell well overseas. What I said was never intended to imply that GM products didn't compete, of course they did, and do, but there is a REASON why other manufacturers sell more vehicles than GM does and are considered to be levels above them...
GM sells to their dedicated base and loyal customers who grew up with the brand, but someone driving a BMW or Mercedes knows their is no comparison regarding tech, which is why BMW's and Mercedes cost more overall. GM does what they do based on feedback from their marketing teams, the techs have no say on what gets developed, only to develop what they are told to. It's about money with them, and there are short cuts involved. EPA requirements vary on many factors, and it is very costly, so even saying that things get done from an emission's perspective is only really part of the story. GM HAS the tech to rival the best out there, but they stretched out what they have been to make a buck, and that is the truth. There is a lot more in the GM toy box so to speak that never seen the light of day, and that is because they are cheap, because they know that further development into those systems will cost them MORE in the long run as opposed to what already works...
#1192
If pushrods were so bad then how come the c5r and c6r race teams did so well? Multi valve per cyl has its advantages but it comes at the price of increased size and cost. Ford coyotes finally started to make some power but they are huge motors lol
#1193
Last time I sat in a Mercedes and a Cadillac at the Chicago Auto show it was obvious why the Cadillac was cheaper. Had nothing to do with the engine but rather the interior was obviously significantly lower in quality than the Mercedes. If I was a luxury buyer that would be a turn off.
In terms of tech, I will say this; How many people (except S2000 owners) go "it has X HP" vs "it has X HP per liter." Few give a damn about the tech involved if has the right numbers.
All companies try to stretch out their tech to make a buck. Welcome to the ways of the world. Even the most exotic of cars like a Lambo will not be built if they weren't making a dollar, and even their tech is evolutionary not revolutionary. The 4 valve engine has been around over 100 years now. It's not new tech by any means, just different tech.
#1194
... that is absolutely hilarious coming from someone with a home built ECM bench, oscilloscope in hand, yet with no code algorithm written under his belt, or anything of that nature. Nothing, nada, zip, just an idle video that I took the time to applaud, yet no real data to back up and view, no runs, nothing. What exactly is it that you know and that I don't lol? Seriously? Have you spoken to any Volvo and Harley techs in the past like I did to see the direction the industry is going? Do you know the cost to GM for revamping their entire ECU system, not to mention the amount of time it would have taken them to perfect while the other manufacturers already had a head start and wouldn't release the code? You think that just because you are an MS user you have some form of edge over everyone else? Think again, I'll bet money I have more experience than you do TUNING and DRIVING a MS powered vehicle. Don't lecture me about something you know nothing about, aside from sourcing and researching the techs from the former manufacturers previously mentioned, I also had to explain to many GM investors how said company was in needed to be bailed out by the tax payers due to poor decision making and flawed products, but by all means. let a handful of nobody's applaud their MAF w/MAP system while the rest of the world keeps pushing forward. That had to be the funniest thing I ever read from you. Gotta love those farm boys.
I'd be very curious how the presence or lack of a MAF has anything to do with their "flaws." All makers have Flaws, even the bullet proof Toyota has had flaws come to light. Most of their flaws were not in powertrain but rather in how to package it (Aztek, badge engineering.)
Personally, substance vs hype my $$$ is on Joe any day of the week twice on Sundays. I really don't think someone who's deleted their build thread multiple times has much room to speak.
#1195
You would consider it more than an experiment lol? It was around a fraction in relation with GM's history, and more found their way at the dealers, and eventually the junkyards not too long after they stopped making them. I guess we have a different definition of what experimentation is, as one should not release a product until thoroughly tested and researched. The Northstar meant well and spawned ideas, but it itself was a flop...
That is your opinion as a buyer, not to mention an opinion based on a biased understanding. You won't admit it, but you told yourself the Cadillac was just as good before even comparing the two for yourself. That is just the way the world is, I will admit that other baseball teams are good, but none hold a candle to the Yankees, even if the Yankees having a losing season. This is why I mean when I say GM sells to their loyal base. Have you ever driven in a twin turbo BMW? Seriously, have you? GM cannot compare with what they currently sell. Endless rumors about a new Buick Avista hitting the scene and putting the Imports to shame, so why hasn't it yet? It's already developed and tested, so why not release it? There is more to production then you realize...
You're speaking on Joe's behalf, meanwhile it is HE who gives a damn about the tech you're criticizing lol. He wants precision, and MAF w/MAP is not the way to go. Ion sense tuning does it all, no more sensors needed, no more crank or cam sensors nor MAF sensors. I'm quite sure this will eliminate jobs, while costing GM a lot to research. Therein lies the reasoning, it is very political, not just because they don't want to...
... lol, there is a difference between cutting costs, only those with major share holders who are expecting a return stretch that buck. As a former Nissan GTR owner myself, I assure you not every company does, and this reflects on past and current sales brand history. People never forget.
You are confused in a narrowing world. It is more revolutionary because the early concepts of Ion sense tuning that you would find on an Isuzu or Saab are completely different systems. Not to mention, if it were so "evolutionary" why hasn't GM capitalized on it? Oh wait, they were squeezing their pennies until Lincoln screamed.
The big differences were that the Cadillac had a plasticy dash compared to the Mercedes and the materials in the seats were nowhere near the same quality or workmanship. Hard to mask that, I'd lean towards the Cadillac personally as I prefer power trains. To that end I'm not the typical buyer of a Mercedes or Cadillac.
Saab? I thought GM wasn't developing this system. Saab was a GM company. Actually they apparently used it on the Saturn ION Red Line too which is an Ecotec engine.
http://www.searchautoparts.com/motor...nse-technology
Lastly, I will point out where's the DIY tuner version of Ion sense if it's a magical tech? People spend a fortune on EMS systems for cars and would likely have little issue spending a few more dollars to simplify their configuration. There's three answers I can come up with, first off it's not that mature, second it adds needless complexity and lastly what's out there is more than adequate in the majority of cases to successfully optimize an engine's calibration.
#1196
If we're comparing credentials, just google my real name in regards to Linux, netfilter, packet steering, transparent HTTPs interception, etc. I've been contributing production code for almost two decades that is probably in millions of devices (Including your android phone, unless your one of those IOS users).
Compared to that, this automotive stuff is so simple it's boring.
-- Joe
#1197
When I first saw this pop up on my phone earlier, I missed the "V8" and was thinking, man, what is he smoking.
The combo is because it's more adaptable. And we're not just talking GM, we're talking like EVERYONE.
I settled on a 2005+ MAF (Slot style), which I suspect is what the Blowerworks MAF is based on. (That all the Corvette C4 guys are not using).
Btw, have you settled on a management system for the new build? Steve has been using the Holley on his twin turbo camaro and so far I guess he's happy with it. The fuel map being DC based is a weird, but at the end of the day it works.
-- Joe
-- Joe
#1198
I accidentally deleted one of Street's posts and now I can't get it back. Damn it.. I'm sorry.
Clicked on the wrong thing, and didn't realize until it was too late.
-- Joe
-- Joe
#1199
-- Joe
-- Joe
#1200
i am done with this pos , my megasquirt is acting up on me yet again , when i start the car now it sounds like the ignition is cutting out, even if i hold the rpms at say 2500 all the sudden the motor just shuts off rpms fall to 500 and it refires over and over again , after about 20 tries to start it it finally runs
the leds on the side of the case #2 and 3 both go out when the motor dies ,tuner studio also disconnects from the ecm but the ecm does not set the reset flag in tuner studio
ive reflashed both cpus with the code , same issues with both
im going to rewire power form the ms directly to the battery to eliminate my arc panel , and im also going to try putting the jump pack on the car to see if either solves the issue but i highly doubt it
im going to pull that pile of trash off the engine and replace it with a bs3 or fast system , unless somone has a cheap alternative
word of advice never ever buy a used ms unless u personally know the person ur buying it from
i have been over every aspect of the wiring,fuel and ignition systems so far today and im confident its the ms unit itself , i even eliminated the ignition system from the ms control with no change
