Single turbo 352 iroc 1000hp or bust the grand finale
Old Aug 5, 2015 | 09:38 AM
  #151
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Single turbo 352 iroc 1000hp or bust the grand finale
Originally Posted by Orr89rocZ
]Well i was refering to daves but any results for guys doing stock block relatively budget builds would be nice to see! I am strongly considering doing my 305 still with a single 70 but i kinda want to just do light port job on heads and cam/intake it as well. Still up in the air cuz i want to take motor out to clean and rebuild anyway.
Just tuned a 383 tpi setup with a d1 making 8.5 psi at 5000 rpm, it made 521/583 so far. I think my basic 305 should get to 350 whp easily
I'm going to bring mine back, most know the setup, but I'll go over it again in a new thread.
Dave has all the time in the world, not sure what is taking him so long. Me on the other hand, I work really long hours during the day, and at night, well, my nights can get insanely busy lol...
Old Aug 5, 2015 | 04:50 PM
  #152
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
IS this thing ever gonna actually be done?
Old Aug 5, 2015 | 04:54 PM
  #153
DIGGLER's Avatar
Actually we have seen that many times before. Its time for a dyno or track vid with results lol no less. Its been 3 to 4 threads in the making now. Enough with the teasing lets get it done
this. i wanna see some action.
Old Aug 5, 2015 | 07:18 PM
  #154
project89's Avatar
im on it i just got another box o parrts from summit racing today , and i have one final box xcomming on friday , going to try to fire the engine up this weekend.
im rushing but im also not i have till spet 19th to have this thing ready
Old Aug 5, 2015 | 08:24 PM
  #155
project89's Avatar
break in oil , new hv/hp oil pump , hardened oil pump drive , 1.5 inch polished 304 stainless tubing for radiator hoses , and my new o'neal riding boots in the box under everything else
Old Aug 6, 2015 | 05:43 AM
  #156
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by Street Lethal
By the way if anyone local needs a 355 SBC short block that ran fine before it was pulled (crank, rods and pistons installed) no cam, no lifters, no timing chain, you can come and get it for a hundred bucks...
- Rob
Ugg. I just spent $600 at the machine shop boring and honing a block for my Corvette... Still need to buy pistons and rods.
What do you have for pistons and rods??
-- Joe
Old Aug 6, 2015 | 07:33 AM
  #157
-- Joe
I have to check, the engine was oiled then wrapped up in the garage to keep it away from the elements, this is the last pic I took when it was last out...;
Old Aug 6, 2015 | 07:41 AM
  #158
Oh gawd, put a lampshade on that thing and you're all set lol...
Old Aug 6, 2015 | 11:31 AM
  #159
project89's Avatar
lmfao
Old Aug 6, 2015 | 05:57 PM
  #160
DIGGLER's Avatar
lmfao
Hahahahaha!! Thats a classic!!
Old Aug 6, 2015 | 07:42 PM
  #161
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Old Aug 7, 2015 | 07:40 PM
  #162
project89's Avatar
if all goes well tonight i shouldhave the engine back in the car tonight , and hopefully doing the break in tommorow. ill take pictures of what i get done tonight
but the final parts showed up from summit today , the only thing i can think of that i dont have is some fittings for the oil return lines put i can pick those up at the hardware store
Old Aug 7, 2015 | 11:05 PM
  #163
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
They got an fittings at your hardware store?
Old Aug 8, 2015 | 01:16 AM
  #164
project89's Avatar
no i need some pipe fittings to weld to the pan to screw my an fittings into , i dont like the bulkhead fittings
i didnt get to work on the engine tonight but will tom, instead i helped my buddy get the one th350 torn down tonight , since i needed some parts out of it
the parts are going in a case, with a jw ultra bell and transbrake/manual vb
Old Aug 8, 2015 | 08:57 AM
  #165
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Make sure you check the clearance with that bell after you install your pump. You may need to grind it more so it sits flush and doesn't hit the case.
I think I had like .010" clearance on mine on the bottom. I suspect different pumps might have different depths as machine tolerances are not critical.
-- Joe
Old Aug 8, 2015 | 10:28 PM
  #166
project89's Avatar
-- Joe
joe im missing 2 springs for the piston in the direct pack can u see if u have them laying around anywere?there was only 15 out of the 17 springs in the bag
ive also got to find out were i can pick up just the input to output shaft bushing
took 4 hours today to figure out there was 2 different height low/rev pistons
first one we were trying the clutches stacked up to high and had negative clearnace after measureing every single piece except the piston we finally figured it out
besdies that the steels i had for the low/rev only had 3 good ones out of the 5 needed , luckily my friend had a new in the box 700r4/4l60 kit and it uses the same steels
will be 3 weeks before my buddy is back in town to finish assembling the transmission for me so i have a lil time. for now im going to drop a stock 700 behind the engine and get it broken in
Old Aug 9, 2015 | 02:47 PM
  #167
project89's Avatar
Old Aug 9, 2015 | 03:43 PM
  #168
project89's Avatar
well i was going to take the day off but i said screw it , heading over to button up the bottom end of the engione and install it in the car , this way on monday i can wire it up and get the engine broken in
Old Aug 9, 2015 | 04:49 PM
  #169
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I've got nothing in the shop for springs.
How much are they?
-- Joe
Old Aug 9, 2015 | 08:04 PM
  #170
project89's Avatar
How much are they?
-- Joe
dont know i sent pete@huges a pm on yellowbullet to see if i could buy them and how much
anychance u know were to get the output shaft bushing?my supposedly complete kit lacked the input to output shaft pushing
Old Aug 9, 2015 | 09:36 PM
  #171
project89's Avatar
got the valves adjusted , checked all the bearings in the bottom end and retourged the main and rod bolts, installed the new hv/hp pump and pickup got the intake bolted on , last thinig to do was weld a fitting onto the oilpan for the single return line and i bought the wrong friggen pipe bung so i had to stop for the day.
ill run down to the hardware store in the am pick up the proper bung and weld up the oil pan so i can get thyat bolted on and get the engine filled with oil prime the motor and put it in the car for breakin
as of tonight when i left the shop
this is were my trans kit was missing a bushing
and the difference in between a stock and machined low rev piston
Old Aug 10, 2015 | 05:56 AM
  #172
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Let me know whatever the fee is and I'll take care of it.
You had the piston machined so you can run 5 frictions/5 steels right?
http://www.transmissionpartsusa.com/...ngs_s/4645.htm
-- Joe
Old Aug 10, 2015 | 09:53 AM
  #173
project89's Avatar
-- Joe
yeah u can see the difference in the 2 drums up above in the picture i posted, those guys dont have the bushing either , found some on ebay though , still waiting to hear back from huge's if i dont hear back by lunch time ill give them a call
edit never mind i think i missed it the first time i looked
34634 Powerglide TH350 bronze output shaft pilot bushing 1969-86
^^^ should be the bushing im looking for wish theese places would post pictures
been meaning to ask u does the tv/kickdown cable need to be hooked up withthat valve body? directions dont say
Old Aug 10, 2015 | 10:13 AM
  #174
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
No TV cable plugged. In fact, the case I sent you is plugged.
Did street lethal vanish again? I PM'd him the other day about his 355. I need pistons and rods for my stingray.
-- Joe
Old Aug 10, 2015 | 10:14 AM
  #175
project89's Avatar
-- Joe
hes around doesnt login every day i think, on my way over to the wshop to get some more work done hopefully ill be posting picvtures of the engine in the car today
Old Aug 10, 2015 | 11:39 AM
  #176
Xter's Avatar
Car: 87 Camaro LT
Engine: 383 Twin Turbo - In progress
Axle/Gears: 3.43
-- Joe
I have a set of summit .30 hyper pistons and the stock connecting rods still on the stock pistons sitting around. And some moly .30 over piston rings. Idk what shipping would be, I was saving these for when I pulled the 350 out of the yukon but I'll let them go cause they're just sitting atm.
The pistons are brand new in the box flat tops, 2 valve reliefs, with brand new wrist pins, they're not floating though, press fit.
Only problem is the one wrist pin is bound in the one stock piston, idk if the connecting rod is ok to use or not. You'd have to press it out and check to see.
The connecting rods and stock pistons I'll do for free, just gotta take care of shipping.
Old Aug 10, 2015 | 02:00 PM
  #177
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
44062 Bushing?
wittrans.com has a bunch of those
Old Aug 10, 2015 | 02:02 PM
  #178
34blazer's Avatar
Engine: LZ9????
Transmission: 2004R
http://www.bulkpart.com/Merchant2/me...50-350Cbushing
Old Aug 10, 2015 | 02:29 PM
  #179
project89's Avatar
seems to be it , i got a pm back from huges on yb.com , needed some more info from me so when i hear back from them ill see if they happen to have that bushing and just grab it from them when i get the springs for the direct piston
Old Aug 10, 2015 | 10:11 PM
  #180
project89's Avatar
i hate to admit it but i didnt touch the car today , changed the oil and plug on my bike in the morning then came home for lunch and it looked like it was going to pour so didnt go back to the shop, of course it ended up only raining for a few mins
tommorow i have to wait for ups to show up as ive got a new pipe and fmf silencer showing up for the bike so tom ill prolly be installing that stuff instead of working on the car , i think i need a few days break from it anyways
on a good note huges is sending me the springs and the bushing im missing
Old Aug 11, 2015 | 03:18 PM
  #181
project89's Avatar
took a day off from the car and installed the new silencer on my bike , now i gota rejet the carbs yet again
Old Aug 11, 2015 | 03:26 PM
  #182
Car: 1979 Malibu
Engine: Blown LSx
less bike updates more car updates
Old Aug 11, 2015 | 03:56 PM
  #183
project89's Avatar
lol i didnt take the day off by choice bike is my daily driver atm since its so good on fuel and were going to get hit with some thuunder storms today , so didnt wanna get caught out in the rain if i rode over to the shop
ill be back on the car for sure tommorow , also heard back from huhges and the parts for my trans shipped out today via fedex
Old Aug 12, 2015 | 10:22 PM
  #184
project89's Avatar
the front end needs to come down about another 1/2 to 1 inch
car should have paint on it this weekend
Old Aug 12, 2015 | 11:47 PM
  #185
project89's Avatar
dropping some music here so i can grab the links easily in the shop tommorow
and
and
Old Aug 13, 2015 | 08:34 AM
  #186
She's looking good Dave...
But, how dare you post a bunch of wannabe's when the kings are STILL out there playing...
Old Aug 13, 2015 | 09:14 AM
  #187
Haha, Joe, I was in fact MIA for a little bit. Too much going on in my life, unfortunately. Engine is gone, local member picked it up days ago. Don't have much left to support both yours and Dave's builds other than a 7" Azpen Android Tablet that may use Megasquirt's Shadow Dash and Logger app and will fit in your radio area, haven't bothered to try and download MS though because I went with a full windows 7" tablet for my setup. I do have the MS apps on my Lenovo tablet though, I might sell that tablet too. Also have a Wii entertainment system in the box with two free games, and an additional three games, if anyone has kids...
- Rob
Old Aug 13, 2015 | 09:29 AM
  #188
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
- Rob
Oh well. Guess I'll buy some new rods and pistons.
I've got a cheap laptop for my MS in the fbody. The vette has a quadrajet
-- Joe
Old Aug 13, 2015 | 02:01 PM
  #189
project89's Avatar
need some old school
Old Aug 13, 2015 | 02:09 PM
  #190
Oh come on now brother, don't forget this one...
Old Aug 13, 2015 | 02:10 PM
  #191
project89's Avatar
btw big update comming after this weekend , i will say im getting tons done but i dont wanna spoil it by letting everyone know whats up or posting pics just yet , expect some good pics and video on sunday night
Old Aug 13, 2015 | 02:24 PM
  #192
Oh hellz no, you teased everyone long enough now lol. I think Justin has just about given up on you lol, so post something up today just as a teaser until Sunday night, you freaking owe it to these members lol...
Old Aug 13, 2015 | 02:28 PM
  #193
project89's Avatar
ill do that tonight i need to grab some good pics when i head back to the shop in about 30 mins, dont expect driving vids yet though as posted above my trans is only half together
Old Aug 13, 2015 | 07:12 PM
  #194
project89's Avatar
u know what this means paint is getting sprayed , need to touch up some spots witht he primer and seal it all tommorow, and then time to spray the base and clear
Old Aug 14, 2015 | 06:31 AM
  #195
u know what this means paint is getting sprayed , need to touch up some spots witht he primer and seal it all tommorow, and then time to spray the base and clear...
It's about time she got some paint on her. Do it right though bro, remove the hatch and doors to get in the jams the right way. If she comes out like the bike did she's gonna look sweet...
Old Aug 14, 2015 | 07:03 AM
  #196
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You have a drive on lift?
How is it?
I have a 2 post. I was thinking of also getting a drive on.
-- Joe
Old Aug 14, 2015 | 07:23 AM
  #197
Here's some inspiration, get it done brother...!
Old Aug 14, 2015 | 11:40 AM
  #198
project89's Avatar
How is it?
-- Joe
its not mine its my buddys , it works well and even has alignment plates , he does alot of transmission and clutch jobs so he got the drive on,
his lift does have the sliding jacking plates as well so u can do suspension work on the lift , he just doesnt have the jacks.
i personally like the 2 post lifts better , but the 4 post is much easier to just get a car up in the air and do what u need to do
Old Aug 14, 2015 | 08:35 PM
  #199
project89's Avatar
well its comming along , its all preped and ready to go except some minor masking
in the morning im going to prime and seal the hood and then seal the rest of the car. if i get done early enough i will spray the base and clear tommorow as well.
if not first thing sunday morning ill do the base and clear
wont be posting any pics till its done on sat or sunday night
Old Aug 14, 2015 | 11:50 PM
  #200
project89's Avatar
song for the shop tommorow morning
