gauges
Old Dec 19, 2001 | 11:10 PM
91 z28 350's Avatar
Car: 91 Z28
gauges
what kind of gauges should i get when i get a super charger boost and what else ???
Old Dec 19, 2001 | 11:37 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I would go with a fuel pressure, air/fuel and boost gauge. Search the archives on other peoples rides with S/C's.
Old Dec 20, 2001 | 06:30 PM
pontiac's Avatar
i'd add exhaust gas temperature (EGT) meter. somebody here will know better why it seems to be important, since many turbo projects have it.
-P (me don't know)
Old Dec 20, 2001 | 06:44 PM
TheCamel's Avatar
Gauges I would use:
Boost pressure
Fuel pressure
Exhuast Temp
Wideband o2 Air/Fuel mixture
Not really needed but nice to have
Charge air temperature
Knock meter (other than the factiry unit, allows you to see problems because you ussually don't hear them till its too late.
Exhaust temp gauge is used similar to a air/fuel gauge, knowing the sweet spot for the engine to be burning at at WOT can be seen in the exhaust temps and helps in the overal tuning of the engine. I am not sure what a Supercharged V8 should be runnning but my Nissan Skyline is 850° C on a 2.0 single turbo application, too high and its running lean, to low and its running rich (rich will cool the pistons due to the extra fuel)
TC
Old Dec 20, 2001 | 09:55 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I think the three most important are boost,knock,and air/fuel or EGT or both.EGT more if your gonna run racegas alot,otherwise air/fuel will do fine
Steve
Old Dec 21, 2001 | 01:33 PM
pontiac's Avatar
with plenty of boost, it's easy to melt pistons just because running too lean or too much timing. knock and EGR or A/F with boost gauge looks like optimal instruments.
-P
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
