Going from a single turbo to twins
Old Dec 11, 2015 | 07:35 AM
  #151
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Going from a single turbo to twins
Thought about those too but not much room on third gens. lol
Old Dec 11, 2015 | 10:16 AM
  #152
Hot side is all done!!!!
Old Dec 11, 2015 | 10:18 AM
  #153
Trimmed the fender exit a little. I like the look.
Old Dec 12, 2015 | 04:03 PM
  #154
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Once you have it all fabbed up, if the quality is high enough (if the materials are known to last under the high temperatures without warping easily) I recommend you coat, wrap, and blanket all of that potentially 1500*F plumbing that is so close to your engine and parts up front.
I also suggest you create a mounting bracket for the turbos themselves ( I don't see anything supporting their weight that does not also get hot). You do not want weight bearing down on the plumbing as it heats up potentially to 1500*F+, as it will tend to bend/warp out of shape.
Old Dec 12, 2015 | 04:24 PM
  #155
Yeah I do plan to make some braces. That's the next thing I am going to tackle.
Old Dec 14, 2015 | 07:08 AM
  #156
Here is an engine bay shot my stepson took
Old Dec 14, 2015 | 07:46 AM
  #157
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
In case you were wondering how close a rad hose could be to downpipe
Old Dec 14, 2015 | 08:23 AM
  #158
That is definitely a lot closer than mine.
Old Dec 14, 2015 | 08:38 AM
  #159
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Water keeps it from melting but it may be heating it somewhat more than necessary lol. I am going to buy a inch shorter hose to pull it away
Old Dec 14, 2015 | 09:38 AM
  #160
project89's Avatar
grab some polished 1.5 inch 304 stainless tubing u bends from summit racing , there like 11 bucks each , i only needed one to make my upper radiator hose .
on the ends i bought some gates hose to use for couplers , be aware that gates stuff is about 26$ a ft but it will prolly outlast the car
then u dont have to worry about the upper hose blowing ut on the road or away from home and being able to get a replacement
Old Dec 14, 2015 | 09:55 AM
  #161
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No need. Running like this for couple yrs now. Never had a issue and dont expect any lol
Old Dec 22, 2015 | 08:45 PM
  #162
drewmac2882's Avatar
I'm getting ready to convert my 84 T/A to a twin turbo set up. What did you use for exhaust manifolds?
Old Dec 23, 2015 | 08:45 PM
  #163
Search for HP Maximizer forward facing turbo headers. They are on sale now. I wish I waited. Lol
Old Dec 28, 2015 | 10:41 AM
  #164
No progress to report as of lately. It has been on the back burner for a little while. Only thing I was able to do was neaten up the sheet metal where the battery tray used to be. I am waiting for my intercooler to arrive so I can set that in place and I should be able to get the cold side done once that's in place.
Old Jan 3, 2016 | 05:43 PM
  #165
Well, I have decided to put off making the cold side. Reason being is something was bothering me when I did a compression test. All cylinders were close to 140 psi except #1 which was at 125 ish. I tore down the engine and pulled out the piston....Rod bearings looked like new. The ring gap was approx. .030 which was way too much. I thought they were set at .024 top and .026 second. Thinking back to when I put this engine together I probably set the ring gap with the ring in the wrong spot. Good news is I have a spare set of rings in my tool box since the day I first put it together. I will be re ringing the engine this week.
Old Jan 3, 2016 | 05:49 PM
  #166
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Alittle extra ring gap never hurt a boosted motor lol
Old Jan 3, 2016 | 05:52 PM
  #167
It does if you blow the dipstick out or have oil on your spark plugs lol Besides I want this engine to last awhile. Eventually I will build another sbc for it but not now.
Old Jan 5, 2016 | 11:39 AM
  #168
I got all new rings gapped and installed last night. Much better now. And will probably have less blowby as well.
Old Jan 5, 2016 | 12:01 PM
  #169
project89's Avatar
just going to ask cause i didnt see u mention it did u run a hone or ball hone threw the cyl?
if not the new rings will never seal
Old Jan 5, 2016 | 02:29 PM
  #170
Not true on the rings will never seal though. Gm does rings and pistons all the time and they say "do not hone the cylinders."
But I have a ball hone which was used on mine last night.
Old Jan 5, 2016 | 07:49 PM
  #171
project89's Avatar
id like to see a leak down test on one of those
i shouldnt say never it depends on the ring type/material , but it will take a long time to seal up , theres no way in hell i would re-ring something without atleast running a ball hone threw it. unless it was a brand new motor with only break in time or something on it that say a ring got broken during assembly and u caught it right away
Old Jan 5, 2016 | 09:11 PM
  #172
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
He's a tech at a dealer, trained on the latest and greatest. We're old farts using old parts.
From a manual:
"The smooth bore finish currently recommended in all Chevrolet engines is largely a result of modern ring manufacturing techniques that virtually do away with lengthy run-in time on new engines to seat the piston rings. All rings are lapped in hardened steel cylinders during manufacture which eliminates the need for a rough bore finish to accomplish ring seating. (italics theirs) Elimination of rough bores one initial build and no rehoning on rebuild results in a sizeable power increase due to decreased engine friction."
If he's using the correct rings, don't hone. If he's using rings that require a hone to break in, then hone.
-- Joe
Old Jan 5, 2016 | 09:15 PM
  #173
From a manual:
-- Joe
Correct and thankyou
Old Jan 5, 2016 | 09:17 PM
  #174
You would be surprised
As far as a leak down after the pistons or rings were replaced the leakdown was "zero"
Old Jan 5, 2016 | 10:54 PM
  #175
project89's Avatar
From a manual:
-- Joe
learn something new every day
im curious what are these new style rings made out of ?
id imagine if the bore gets out of round they wouldnt work well though
Old Jan 5, 2016 | 11:11 PM
  #176
Yeah. If the bore was out of round then engine gets replaced
Old Jan 5, 2016 | 11:44 PM
  #177
jimw67's Avatar
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
I find that hard to believe. New rings of any type in a used bore has perfect seal?
I do understand that the technology is improving/changing, but I had the understanding of just the opposite of what you're describing which is the break in period of this type of ring is one or two heat cycles, BUT their is a break in cycle just the same as the older technology. Hence, my initial response that I find it hard to believe that you're leak down rate is at zero without a break in period.
Can you supply the part number of the ring set? Did you have an oil consumption issue? If yes, then whay was it?
Old Jan 6, 2016 | 06:59 AM
  #178
I was talking about the GM vehicles that ive worked on that after doing rings there was no leak down and Were Not Supposed to touch the cylinder walls with anything.
Old Jan 6, 2016 | 07:09 AM
  #179
Now to get back on topic instead of arguing about ring seat and leak down.
Ordered a set of 200 cc Patriot heads already setup for Hyd roller cam and some new mls head gaskets. Maybe ill get that done by the weekend.
Old Jan 7, 2016 | 01:52 PM
  #180
Picked up the new heads and swapped over the springs from my Trick Flows. And set the header on to see how they fit. They fit well
Old Jan 8, 2016 | 07:55 AM
  #181
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why did you use the trickflow springs?
Which ones did you use, the 1.25 or the 1.46 ?
(I used to use trickflow heads)
-- Joe
Old Jan 8, 2016 | 08:13 AM
  #182
I used my Howards 98441 SPRINGS that I put on the Trick flow heads. I put the new springs ,retainers and keepers that came with the new heads onto the trick flow heads.
Old Jan 8, 2016 | 08:15 AM
  #183
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ahh, cool!. What did you end up with for pressure and such?
-- Joe
Old Jan 8, 2016 | 08:38 AM
  #184
Installed the springs at 1.750" . 175# seat pressure
Here are the specs...175@1.750" Seat Pressure - 400@1.150" Open Pressure - 375 Rate - 1.050" Coil Bind
Old Jan 9, 2016 | 05:43 PM
  #185
Installed the Mls head gaskets ,installed the new heads and head bolts. Tomorrow I will finish up the top end and hopefully get the intake back on. I also need to re finish my valve covers and have two 12an fittings welded on them. I'll post pictures up tomorrow.
Old Jan 9, 2016 | 10:14 PM
  #186
Well. I decided to tinker a little bit more and now have the driver side pushrods and rocker arms all set. But I forgot to take a dang picture of it.
Old Jan 10, 2016 | 07:48 PM
  #187
Some more progress today. Made more headway than I expected.
Attached Thumbnails Going from a single turbo to twins-img_2860.jpg   Going from a single turbo to twins-img_2861.jpg   Going from a single turbo to twins-img_2869.jpg   Going from a single turbo to twins-img_2867.jpg   Going from a single turbo to twins-img_2868.jpg
Going from a single turbo to twins-img_2870.jpg   Going from a single turbo to twins-img_2871.jpg   Going from a single turbo to twins-img_2872.jpg   Going from a single turbo to twins-img_2874.jpg
Old Jan 14, 2016 | 09:37 PM
  #188
This weekend I will be getting some fittings welded onto my valve covers by a friend of mine so I will ask him if he can relocate and weld the outlet on my intercooler.
If so I should be in luck and not have an issue running the intercooler. The wheels were turning in my head today and I think this will work.
Old Jan 16, 2016 | 07:37 AM
  #189
I chopped and relocated the outlet on the intercooler. Taking it tomorrow to a local friends house to get welded and to have a plate welded where the outlet used to be. Also getter some fittings welded on to the tall aluminum valve covers for my catch cans.
Old Jan 17, 2016 | 03:44 PM
  #190
Finally installed the intercooler. Looks like I'll be using hood pins to keep the hood closed. Valve covers are all set to even though I may have to repaint one of them (didn't come out perfect).
Attached Thumbnails Going from a single turbo to twins-intercooler-1.jpg   Going from a single turbo to twins-intercooler.jpg   Going from a single turbo to twins-valve-cover.jpg
Old Jan 24, 2016 | 07:39 PM
  #191
Not much to report lately. Only thing I have gotten done is the catch canisters hooked up, some cold side tubing ordered and some silicone pipe unions ordered.
Old Jan 25, 2016 | 11:36 PM
  #192
Managed to get the tubing from the intercooler to the passenger side turbo finished .
Old Jan 28, 2016 | 06:33 PM
  #193
slowsi's Avatar
Car: 89 Iroc
Engine: 5.0L
how was your single turbo setup?
Old Jan 29, 2016 | 11:19 AM
  #194
It worked well. Only reason I went with twins was because my buddy called me up when he was parting out his 82 Camaro. He ended up selling the car as a roller and I bought the turbo stuff from him.
Old Feb 2, 2016 | 10:17 AM
  #195
I am going to finish up the piping from the intercooler to the throttle body by this weekend. I have also dropped all the hot side tubing and headers off to be ceramic coated as of yesterday. I should have them back by next weekend hopefully.
Old Feb 7, 2016 | 06:06 PM
  #196
Slow progress still. Managed to get my pullies and accessories cleaned and painted. I should have the exhaust this week. I hope
Old Feb 7, 2016 | 06:10 PM
  #197
picture looks way better on my phone
Old Feb 23, 2016 | 07:15 AM
  #198
Here's an update. Finally picked up the headers and other tubing from the coating place. These headers were a pita because there isn't much clearance to get a few of the header bolts in. I will see how this holds up over the summer.
I am hoping I will not have to change anything g with the headers or tubing.
Old Feb 23, 2016 | 07:16 AM
  #199
Another
Old Feb 23, 2016 | 07:25 AM
  #200
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Now that came out nice!!
-- Joe
