Supercharger cold air intake.
Old Jun 13, 2016 | 08:49 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
So i recently supercharged my car a few weeks ago, and ive come to the conclusion that the factory vortech air filter sitting over the header kinda kills power. Car run substantially stronger in the mornings when everything is still cool. Has anyone figured out some sort of a cold air intake, or a tubing set up for these? I was thinking along the lines of a 3.5" flexable tubing setup to run inside the D/S fender area but apparently nobody makes 3.5"
Old Jun 13, 2016 | 11:57 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Supercharger cold air intake.
you can make your own using Spectre piping. just route as you see fit and weld the pipes together.
http://www.spectreperformance.com/ca...?cat=C00000064
i used their 4" diameter pieces to fabricate my own custom CAI system for a '72 Camaro i used to own.
Old Jun 13, 2016 | 01:44 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What blower is that? EFI?
-- Joe
Old Jun 13, 2016 | 09:49 PM
battmann's Avatar
That's a B&M 144 blower with a B&M Superjection EFI system on it. It was basically an analog computer controlled 1,000 cfm carb. I used some short solid Moroso motor mounts to lower the engine about an inch and this whole thing fit under the factory second-gen camaro hood.
I think you can still get parts for this system from the website below. The owner's name is Bruce. Super knowledgable and helpful guy.
http://www.auto-nomics.com
Old Jun 14, 2016 | 06:18 AM
Car: 86' IROC
Axle/Gears: 3.45
I was thinking more along the lines of a plastic/rubber hose, Id have to make some sharp bends between the blower and master cyl
Old Jun 14, 2016 | 11:42 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Wrap your driver's side header if you can. also you can make a heat shield out of aluminum from home depot and put it between the filter and header. With my master cylinder so close to the filter, I stopped wasting time trying to make a cold air intake go the the cowl of the hood, I would need a 4inch cowl hood anyway, not enough space under the stock hood for 4" pipe.
DARKmj16
Apr 13, 2016 07:42 PM
Donald Croes
Apr 7, 2016 09:22 AM
propaintball96
Fabrication
Apr 4, 2016 01:18 PM
azcamaro
Mar 23, 2016 07:24 PM
camaro1185
Mar 22, 2016 06:41 AM
