C2YT's Turbo 4.8l LSX Swap
Old Nov 15, 2017 | 11:22 AM
  #101
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Re: C2YT's Turbo 4.8l LSX Swap
Bought a used 4l60e torque arm clamp on LS1 tech for the car. Just a matter of putting the driveshaft in, 2 bellhousing bolts, crossmember, and torque arm in! Then the car is on the ground for good I believe.
V-Bands should be here this weekend to start the fab work on the hot side. From there it is just a lot of pictures and mocking parts up! Still need to purchase an intercooler kit, injectors, hp tuners, belt, and a fuel system. I think that should basically wrap it up besides the wiring.
Old Nov 17, 2017 | 07:50 AM
  #102
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
At this pace, it should be ready for the MIFB Meet & Greet for sure. Can't wait to see it.
Old Nov 17, 2017 | 10:32 AM
  #103
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Hopefully! That is what I'm shooting for. I would like to have all the fabrication done here in the next few weeks.
Old Nov 22, 2017 | 12:03 AM
  #104
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Did some work on the hot side today. Not artwork by any means, but should work great! I may have to modify the driver side as I underestimated how tight it is with the power steering line. Anyways, here are some pictures.
Old Nov 30, 2017 | 03:07 PM
  #105
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Forgot to post the good stuff!
Old Dec 1, 2017 | 12:51 PM
  #106
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Well done...
- Rob
Old Dec 1, 2017 | 01:36 PM
  #107
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Thanks! Obviously could be cleaner, but not bad. The V6 stuff was much easier as it was a log setup. Merging the two pipes was a lot of fun... haha
should have the cold side together this weekend! Then onto final assembly haha.
Old Dec 2, 2017 | 08:21 AM
  #108
DynoDave43's Avatar
Looking good!
Old Dec 2, 2017 | 11:54 AM
  #109
Inkaddict54's Avatar
Transmission: 4l60e
What water pump did you use ? Also can it the alternator be on the bottom of the motor and the a/c compressor on the top left of the motor?
Old Dec 3, 2017 | 08:44 PM
  #110
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Thanks dave!
Got everything painted this weekend with high temp paint. Bought the hole saw to do a hole for the 4th gen radiator so it can sit in it's final spot. Have to figure out one of the radiator hoses as well, but shouldn't be a big deal.
Then it is going on to building the cold side!
Inkaddict, I used the fbody water pump with the spacers. As far as the alternator, i'm sure you can put it wherever you like with a bracket kit. I'm not using AC so I cannot comment on that.
Old Dec 3, 2017 | 11:25 PM
  #111
Transmission: 4l60e
You didn't have to do any drilling and tapping ? I'm trying to order everthing for my build right now I just need to get the car up and running . I’ll figure a/c out later lol.
Old Dec 4, 2017 | 08:21 AM
  #112
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
John, Long time lurker and follower first time poster!
Glad to see it coming along, I recognize that turbo! Few questions, stock trans and stock convertor? Also are you still running a stock thirdgen rear? I cant remember if you had a 3rd gen one or 4th gen one when you had the wagon wheels on it. I like the idea, budget LS swap just never seen one actually completed. So I will be following along.
What do you plan on spinning this thing to? What HP are you expecting and hoping?
Also, after I get my house set up and my "winter" project going on my car I'll bring it out to see how well of a upgrade that was from your v6 turbo!
Keep trucking man!
Old Dec 4, 2017 | 08:24 AM
  #113
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
John, come get that 9 bolt and 3.70 setup out of my garage. I'm thinking it'll help you along the way (or maybe down the road). Looks good so far, bud. That is one massive turbo! Spin it to the moon!
Old Dec 8, 2017 | 01:12 AM
  #114
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
good info .good luck with your build . waiting for track / dyno numbers
Old Dec 12, 2017 | 02:22 PM
  #115
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Ink, there is no drilling or tapping needed!
Darren, yes stock converter and stock 4l60e. I didn't want to put the money into the 4l60e if it will be upgraded or swapped out down the road. End goal would be a t56 I believe. I would really like to see the car go manual one day. Running a stock 4th gen rear with 3.73 gears I believe, might be 3.23. Has a T/A Girdle, but that is about it. Planning on probably a 6000 RPM redline since it is on stock springs and stuff. Should still be fun and have lots of room for improvement. Estimating probably 400-450 horsepower with lots of room to grow. Next year will be trans and rear end then I can start to turn the car up more.
Mike, I'll make it down there this weekend! I'm sorry, been so busy with finals and everything else going on in my personal life. Cars have been at the bottom of the priority list.
Freaky, thanks for the kind words! It probably won't hit a track anytime soon but may see a dyno eventually. Stick tires, stock 4l60e, and stock rear end doesn't sound like much fun to me LOL
Old Mar 13, 2018 | 09:18 PM
  #116
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Not much to update. Busy with school and work, but will be graduating in April!
Old Mar 14, 2018 | 01:38 PM
  #117
Streetstuff's Avatar
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
Hey how did the ICT billet mounts work for you? I had to have a friend sit in the engine bay in a rowing position with a crow bar while I impacted the bolt through the engine mount hole. The alignment was about half an inch off for me.
Old Mar 14, 2018 | 02:42 PM
  #118
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I had to do the same thing a year ago with a friend on here with his lsx firebird. It was not fun. Phoenixfirebird
Old Mar 14, 2018 | 02:53 PM
  #119
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
I think it's because ICT makes them thicker than they should be for strength since its not steel. If the engine ever comes out, those are NOT going back in.
Old Mar 14, 2018 | 03:53 PM
  #120
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Actually worked fine! Our biggest problem was doing the trans and engine at the same time. We did have to use a crowbar to get the engine to drop in, but once it was in there it was tight! Everything lined up good though.
Old Apr 15, 2018 | 06:07 PM
  #121
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Crappy photo, but getting closer! Current running total included as well.
Old Apr 15, 2018 | 06:10 PM
  #122
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Items Bought:
VS Racing 7875 Turbo $ 280
4.8l Engine $ 300
Ebay 50 mm Wastegate $ 30
Ebay 50 mm BOV $ 30
Boost Controller $ 30
4L60E $ 250
Torque Converter $ -
Fbody Water Pump $ -
Engine Mount Bracket $ -
LS1 Intake $ 100
LS1 Fuel Rails $ -
Fbody Oil Pan $ 50
Fbody Pickup Tube $ -
Fbody Oil Pan Gasket $ -
Fbody Dipstick $ -
Fbody Dipstick Tube $ -
AC Delco TC Bolts $ 4
Anchor V8 Mounts $ 10
Felpro TB Gasket $ 3
Felpro EM Gaskets $ 10
Fragola 6ft -4 AN Line $ 15
Fragola 6ft -10 AN Line $ 30
ICT Billet GT42 Oil Feed Flange $ 12
ICT Billet IM Gaskets $ 20
ICT Billet IM Bolts $ 17
ICT Billet Bellhousing Bolts $ 10
ICT Billet EM Bolts $ 15
ICT Billet -10 AN 45 Degree $ 13
ICT Billet -10 AN 90 Degree $ 13
ICT Billet -10 AN to 1/2 NTP $ 7
ICT Billet -4 AN 90 Degree $ 10
ICT Billet -4 AN to 1/8 NTP $ 7
ICT Billet -4 AN Straight $ 7
ICT Billet ALT/PS Bracket $ 180
ICT Billet Motor Mount Plates $ 30
NGK TR6 Plugs $ 15
Dorman MM Bolts $ 6
2x 2.5" V-Band $ 28
1x 3" V-Band $ 8
T4 Flange $ 14
LS1 Fbody Windage Tray $ 20
2x 2.5" U-Bends $ -
1x 2.5" 45 Degree Bend $ -
Craigslist Intercooler $ 50
2.5" Intercooler Piping $ -
80lb Deka Injectors $ 106
Injector Adapters $ 20
Plug Wires $ 20
Starter Bolts $ 10
Total: $ 1,787
Old Apr 17, 2018 | 06:24 PM
  #123
DynoDave43's Avatar
You're getting there!
You ought to swing by MIFB with this update. Brian has reworked the forum, and it's MUCH faster now, and easier to navigate.
Old May 15, 2018 | 01:31 PM
  #124
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Looks good! Glad you went with the VS 78/75 over the GT45. GT45 is bulletproof and only $180 but it would have spooled around 4k on a 4.8. Also the 78/75 you got isn't the billet version... looks like the cast but thats more than enough for your HP goal, if you got the billet for $280 I would have been pissed lol. I picked up a VS 78/75 cast for $330 new like a month ago. Its going to replace my 76/65 on my 5.3 depending on how i end up running this thing. 10psi is impossible to keep tires hooked so get ready to have some fun!! My 76/65 uses a CX hotside (3" yuck) but my logs show MAP 100+kpa starting at 3k with no real load bc the tires just spin.
hard to tell but you got got some angle on that turbo... hope you dont have drainage issues.
Old May 16, 2018 | 07:58 AM
  #125
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Once you get it done you better be able to pull away from my IROC down the sigler speedway in south rockwood or you'll never catch the end of it
Looks good bud - can't wait to see a finished product. Then again they're never really finished products, are they?
Old May 31, 2018 | 09:29 AM
  #126
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Still here, getting close. Finishing up the wiring, a couple hot/cold side touches, and then I just ordered a racetronix fuel rail kit and regulator. Should have the first start in a few short weeks.
Old May 31, 2018 | 10:03 AM
  #127
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I am diggin the black and red two tone car
Looking good so far
Old May 31, 2018 | 02:57 PM
  #128
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Thanks! It is getting there!
Old Jun 1, 2018 | 08:15 AM
  #129
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Well, figure I owed a good reason as to why the camaro isn't done yet. Haha. On top of graduating from EMU with my B.B.A in Marketing, I started working full time at Tenneco in Monroe, Mi. It has been a lot of fun, working on the training side and also performance brand management (DynoMax, Thrush, and Rancho). It is crazy to think that when I joined TGO in 2014 I was only a junior in high school working my first job.
It all snowballed after the BMW M-Parallel wheels.... LOL
Some of the local guys knew about the new car, just a fun daily. But a fun daily that snowballed into FBO, MHD Stage 2+ Flash, Alpina Stage 3 Trans Flash, and some other goodies...
Also, shameless plug, if you are not on the Thirdgen Camaro and Firebird group on facebook you are missing out! Great page ran by a great guy named Brian Johnson if you haven't met him.
Old Jun 4, 2018 | 07:41 AM
  #130
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Exhaust is done, just needs to be heat wrapped. Charge pipe is also prettymuch done. Need to run to the junkyard and rob an IAT sensor and an OBD2 port this week.
Old Jun 5, 2018 | 08:29 AM
  #131
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Well, getting closer! Don't mind the cobbled fuel system. Waiting on my Racetronix order to come in and it will replace it all. Went with one of their regulator setups and fuel rails, all -8 AN in preparation for the LS1 tank and twin 255's going in over the winter. Flex fuel will be a great addition.
Old Jun 8, 2018 | 06:09 AM
  #132
fasteddi's Avatar
Car: 1991 Camaro RS
Looking good by oh my.... side fender exhaust for a non race car? That should be interesting and loud lol
Old Jun 8, 2018 | 01:43 PM
  #133
DynoDave43's Avatar
He'll get extra love from law enforcement with that during the Dream Cruise for sure.
Old Jun 8, 2018 | 03:18 PM
  #134
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Oh yeah, lots of fun... haha.
I usually don't drive like a total idiot, so I should (hopefully) fly under the radar. If not, a fender is $50 and the car needs to be repainted again anyways. Haha!
Racetronix stuff should be at home!
Old Jun 9, 2018 | 01:14 PM
  #135
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I left Facebook a few years back before it was popular to make Facebook groups as opposed to Forums like this. I'm hesitant to go back for many obvious reasons that have been in the news lately, so what is the draw or so great about the Facebook thirdgen groups or whatever groups on facebook?
Old Jun 15, 2018 | 08:33 AM
  #136
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
@Tibo it really has changed in my opinion. The group that I help monitor is a no-BS group. It is really for those who are passionate about the platform and have something to offer/help/share.
In other news, got the harness hooked up. Went to connect the battery and it blew my inline fuse for the 12v pcm wires. Unhooked sensors one by one and tested. Still blew. Unhooked c100 and tested. Still blew. Unhooked PCM and it did blow.
Diagnosed one of the 12v pcm wires is the short. The problem must be inside the pcm because once it is disconnected the fuse does not blow.
Have a 411 on the way from a buddy of mine. Hoping to toss it in, remove vats, and fire it up. Then all that is left is filling the radiator, plumbing the vaccum lines, installing the wideband, and looming the harness. Fun!
Old Jun 20, 2018 | 08:55 AM
  #137
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Well... as it turns out you can put the blue covers on the red connector and the red covers on the blue connector. Thanks to Shaun Norton for helping me out at 9 PM last night giving me some guidance and verifying pins for me.
Should be able to hook it up now and flash the 411 for start up.
Old Jun 23, 2018 | 08:59 PM
  #138
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Where you going to put the air filter?
Old Jun 24, 2018 | 08:02 AM
  #139
Car: 87 TA clone
yea it’s gona be loud but not that bad. I installed a cutout where the cat would be right after the tranny on my car and With both the 76/65 and 78/75 when I open it up it’s a whole new animal. Really only “loud” below 40mph but not like an open exhaust as the turbo does a good job as a muffler. I prefer the cutout and full exhaust so it’s super quiet until I open it up. It also spools faster and makes more boost with the cutout open with awsome turbo spool noises. Cutout closed you don’t get any of that
Old Jun 25, 2018 | 04:44 AM
  #140
fasteddi's Avatar
Car: 1991 Camaro RS
I had no exhaust for years with my many Turbo V6s, they got annoyingly loud after so long. I mainly drag race mine only but I did drive to the track every weekend. Turbos do a good job of muffling the sound but it's still is gonna be loud it would be different if hes racing but considering this is a daily driver only it's kind of weird.i don't understand why he didn't run the exhaust out the back it's not that much harder.but regardless, John's done great with this build. Cant wait to see that puppy on the road.
Old Jun 25, 2018 | 12:38 PM
  #141
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Thanks guys, got the car started this weekend and idling. Finishing up the harness tonight with loom and tape.
Going to put one of those mesh caps over the inlet for the turbo instead of a traditional filter. Should have planned better.
Car isn't that loud actually, was really surprised lol. I have always wanted a fender exit. The V6 dumped right under the passenger and I was fine with it. Car isn't really a "daily" anymore, it has succumbed to weekend toy status.
All in all it is coming together. Should be on the road here soon!
Old Jun 25, 2018 | 02:45 PM
  #142
fasteddi's Avatar
Car: 1991 Camaro RS
You should take that puppy up to milan with me. I got my 509 bbc in and I'll be out at the track in 1 or 2 weeks.
Old Jun 26, 2018 | 08:20 AM
  #143
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Haha maybe! Got the harness on last night, it is just small stuff left now.
Old Jun 27, 2018 | 08:51 AM
  #144
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Its coming together nicely! Good job
Jay
Old Jun 27, 2018 | 09:58 AM
  #145
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Thanks! Some more photos. Don't mind the leftover wires. MAF is off to the left, i'm sure i'll find something to put those wires to good use (probably ethanol sensor). The C100 is still hanging out and about. Car is heavily oxidized from sitting outside. Intake piping / BOV is just chilling on top there.
Old Jul 5, 2018 | 08:43 AM
  #146
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Blah. No signal coming from the PCM fuel pump signal wire that ties into my fuel pump relay. Turn key and it does not prime. Hook up a 12v to the test connetion (red wire from relay) and it primes.
One thing after another over here! It has been so damn hot I have not been able to work on the car. Picked up a '70 cutlass and have been enjoying that. Only has 30k original miles!
Old Jul 5, 2018 | 05:42 PM
  #147
DynoDave43's Avatar
Supposed to cool down some tomorrow, and still be decent Saturday.
Old Jul 17, 2018 | 08:12 AM
  #148
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Blah, been tinkering here and there. Car will start, runs like crap, shoots a flame out of the intake. Starting a from-scratch tune instead of using someone else's mistake.
Had to put a new starter on. The old one decided to give up the ghost lol. I felt dirty putting a $100 starter on a $200 engine.
Old Jul 17, 2018 | 11:04 PM
  #149
DynoDave43's Avatar
Hang in there. You'll get it.
Old Jul 24, 2018 | 09:19 AM
  #150
C2YT's Avatar
Car: 1991 Camaro RS
Engine: 4.8l LS
Transmission: TH350
Well that was no fun. First real start, idled great, reved great, no problems, then made an awful knocking noise and puked oil all over the ground. That is a first!
ISO LS1 Oil pan, and a new short/longblock.
Good news is that I was able to get 70% of the stuff off and ready to pull the engine in two hours. It is nice knowing how everything goes together, even spent 30 minutes looking for a 10mm that I gave up on. All that is left is fuel lines, power steering line, pcm connections, and obviously the trans.
