Water/Methanol Injection OR Nitrous
Old Aug 25, 2017 | 09:45 AM
QikNick's Avatar
Car: 1985 Camaro
Engine: SBC 355
I am in need of an intercooler for my setup but unsure which way to go. From the tech articles ive read the water/meth injection brings intake temps down around 50% and allows more timing and boost to be applied. However there is no information ANYWHERE about the differences nitrous creates in air temperature in conjuction with boost. Obviously with nitrous you would need to further reduce timing but horsepower gain (maybe) substantial. Has anyone done this or know anyone who has run a nitrous/roots blower combination. My blower is small (177ci) unit and heat is becoming an issue. Any advise, thoughts, or opinions are greatly appreciated!
Old Aug 25, 2017 | 10:05 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Water/Methanol Injection OR Nitrous
Do not use nitrous. While it may cool air temps somewhat, it adds power, which is just more cylinder pressure and burning more o2 violently as in nitrous applications, this will just make it more detonation prone
Water meth if you cant fit a good air air or air water
Old Oct 27, 2017 | 03:10 PM
WaterPumper's Avatar
I pieced together a "meth kit" myself out of a washer fluid pump from a civic and an adjustable pressure switch to kick it on. As far as I'm concerned theres no reason not to have meth when you're adding tons of heat and horsepower.
Old Oct 27, 2017 | 09:26 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
i use meth on my TTA, works good with the crappy california gas.
Old Oct 28, 2017 | 09:48 AM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Water/Meth all day even though I have nitrous too, but have not used them both yet.
Old Nov 4, 2017 | 09:52 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
I use methanol injection on a kenne bell mustang. You can run 93 octane and alot more timing an boost. I have no intercooler either. If you take the standard of 10° increase per lb of boost added to the iat of say 80° at my 14lbs boost I should see around 220° I see 125°iat under boost. In reality it should be much higher. Because reality my intake temps with heat soak is around 150 iat. So 14lbs would be 280°. Like I said I see around 125°on boost. I have an AIS system. Has its own 3 gallon tank with pump built unto the bottom of it. You cant beat methanol injection. I could inject more and have the ecu pull out fuel but Im on a stock ecu. Point being you could get the temp down below ambiant. With an air to air you cannot. It goes as low as the air temp across the intercooler. I personally wouldnt run two power adders. Nos if there is a hiccup you can melt a motor fast. To me either running more boost and more timing can make up for say running a 100 shot. You can add that in timing and boost easily with no detonation. Mix M1 VP and distilled.
Old Nov 5, 2017 | 07:32 PM
NoEmissions84TA's Avatar
I don't know the answer, which is why I'm asking this "stupid" question.
I would imagine methanol is expen$ive.
Snow's Boost Juice, a premeasured and bottled 50-percent-water/50-percent-methanol mixture. This formula can also be duplicated using blue -20-degree-rated windshield washer fluid that's "spiked" with 3 bottles of Heet fuel-line antifreeze (99.9 Methanol).
https://www.snowperformance.net/category-s/168.htm
http://www.dragzine.com/tech-stories...injection-101/
I found some RV antifreeze good to -50 degrees with no additives or special ingredients.
I wonder how this would work???
Old Nov 7, 2017 | 01:11 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
"Cheapest" per say is mix your own. $8 gallon M1 VP makes 2 gallons 50/50 mix. Dont use the winshield washer as it has alot of additives in it as well.
Old Nov 10, 2017 | 07:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Methanol should be cheaper than 8 a gallon but guess it depends whos selling. but it is nicer to mix your own. I used washer fluid and it worked good enough, but i cant say how it would effect things in long term
Old Nov 10, 2017 | 07:38 PM
I read the labels at Napa today.
They had both the blue stuff (-20) and the pink RV stuff (-50).
Blue - Methyl Alcohol
Pink - Propylene Glycol
Old Nov 10, 2017 | 07:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You want the methyl alcohol. Blue
Old Nov 11, 2017 | 08:51 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
M1 VP is like 8 something a gallon. Expensive.
