COMP Cam for 305 TBI?
Car: 1989 Chevy Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi
how would this cam be in a stock 305 tbi? i want to break 250hp and sound sweet!
(https://m.summitracing.com/parts/cca-12-600-4)
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: COMP Cam for 305 TBI?
Two things, if it says thumper on it then back away they are junk poser cams.
Second if your engine is a 1989 then you have a roller cam. Stay with a roller cam and never downgrade to flat tappet
Car: 89 Firebird
Engine: 355 TBI
Doubt you would ever reach 250 HP with the stock 187 heads. Certainly use a better roller cam, get a GOOD set of headers + matching y-pipe, drop in some L30 Vortec heads and the correct fueling and tuning you could get there. NO cam alone could coax 80 more HP out of that engine alone though trust me.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
- Rob
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
Crane 2032 Grind. Make sure to match the Springs & Retainers. The smaller TFS heads would work well too with that cam. Then Intake and Exhaust to get it working right. Along with a Tune of course. That would meet, or exceed your goals.
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Vortec's and a 212/222 435/460 lift cam will get you there. mine did 351rwph with 5 lbs boost. mine was a flat tappet cam too.
And it's really not a big cam. For a 305 guess it is though.. Had Crane Gold 1.6rr's too. It ran hard. Ask the Bolt on LS1's in my Neighborhood.
Car: 86' IROC
Axle/Gears: 3.45
But thats some really good numbers! How much boost and what setup? Im hoping for 475-500 if im lucky this year with the setup in my sig Joined: Jul 1999
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
my 305 with the crane 2032 cam did 380/420 to the wheels on 14#
