This is cool
Old Oct 29, 2017 | 12:04 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
This is cool
I have seen people take turbos from diesels and put them on their sbc, i am wondering how common it is to see and the practicality of doing this
Old Oct 29, 2017 | 12:14 PM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Re: This is cool
If you find a good one and set it up right, could last forever, boost it too much, boom, as with any power adders.
Old Oct 29, 2017 | 05:39 PM
SketchyZed's Avatar
Engine: 5.7
Re: This is cool
Just wondering, max boost for me would be 6psi or 8psi my goal is just 500hp
Old Oct 30, 2017 | 08:22 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
Re: This is cool
Pretty sure roadkill put a powerstroke turbo on a stock carb'd 302 and it made like 550 crank horsepower. The trick is having your fuel system up to par and not having the turbo cram 30lbs of boost down its throat. Timing is key too.
Old Oct 30, 2017 | 08:27 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: This is cool
Yeah some diesels of various makes do come with turbos that are suitable size for v8 use. I believe some borg warner s400 stuff was oem for some diesel engines. Not sure what ones but they are out there
Old Oct 30, 2017 | 03:01 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: This is cool
Then you need to be making 335 horsepower naturally aspirated.
Old Oct 30, 2017 | 05:33 PM
SketchyZed's Avatar
Engine: 5.7
Re: This is cool
after my heads and cam swap i should be pushing that number out
Old Oct 30, 2017 | 10:18 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: This is cool
A lot of the Borg Warner turbos like the T6 s400 series were made for diesels and tons of people use them. I've got a s480 going on my 6.0L in my 91 Z
Old Oct 31, 2017 | 02:12 PM
SketchyZed's Avatar
Engine: 5.7
Re: This is cool
Just how much would you say this would cost new, hx35 turbos turbo manifolds custom made or new ones all the pipes intercoolers wastegates bovs oil plumbing how much would you say that would be?
