SBC SINGLE TURBO PROJECT
Old 09-19-2018, 07:54 PM
  #101
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: SBC SINGLE TURBO PROJECT
Would this racetronix Hotwire kit work on my 1989 V8 GTA or are the connections different?
http://www.fullthrottlespeed.com/rac...-trans-am.html
thanks in advance!
Old 09-25-2018, 05:29 AM
  #102
Street Lethal's Avatar
The two plug and play connectors on the left side of the picture seem to be compatible by appearance. I would venture to say yes, but would give Racetronix a call anyway just to confirm...
- Rob
Old 09-26-2018, 09:32 AM
  #103
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Here we go....
bought and paid for....
https://www.racetronix.biz/product.asp?ic=fpwh-005
soooo disappointed that summer has zipped by.... (it’s been very cold and wet here the last few weeks, 37*F/ 3*C at the moment)
too many obligations to finish this project before it snows....
I’ll keep plugging away over winter I guess... sigh
Old 02-11-2019, 06:52 AM
  #104
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Brought my 80lb injectors to get bench tested....
I’m glad I did!!!!!!
Old 02-11-2019, 07:45 AM
  #105
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
What brand injectors? Thats no good!
Old 02-13-2019, 08:45 PM
  #106
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Bought new injectors....
Real Deka 80’s I’ve been assured...
+-2% balanced and blueprinted
They’ll get flowed and bench tested anyways....
Old 03-07-2019, 09:03 PM
  #107
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Here’s a YouTube update
Old 03-12-2019, 09:37 PM
  #108
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Old 03-12-2019, 09:38 PM
  #109
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Old 03-13-2019, 11:15 PM
  #110
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Keep going!
I hope your combo is ready for this summer!
Old 03-14-2019, 02:25 PM
  #111
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Making good progress keep it up
Old 03-14-2019, 11:34 PM
  #112
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Comin together....
Still lots to do though...
I have to find a T-fitting for the oil pressure sending unit and oil feed line to share the same oil source at the oil filter site.
I believe that the oil pressure sending unit is a 1/4" NPT and the oil feed line is 1/8" NPT.
I hate trying to find fittings for all of this stuff.
Was gonna order braided lines and fittings for the transmission fluid cooler too.... I think they're both 1/4"NPT in and out of the tranny (700R4)
Gonna need some help/suggestions with the re-pinning soon, but I'm gonna wait till its warmer and the wires are a bit more pliable...
Old 04-20-2019, 12:35 AM
  #113
GTA Sammy's Avatar
Car: 1989 T-Top GTA
GTA TURBO PROJECT STAGE 8 JUST WENT UP YESTERDAY
Downpipe gets a wideband bung....
and turbo gets oil
Sorry there’s not a lot of production in these vids but it’s mostly there for me to look back on...
if it helps somebody along the way, Great...
Old 04-20-2019, 12:41 AM
  #114
GTA Sammy's Avatar
Car: 1989 T-Top GTA
STAGE 9 INTERCOOLER AIRDAM/SCOOP
A little metal fabrication
Its ugly, and will probably need a few design changes as we go but for now I’m moving forward
Old 04-20-2019, 12:43 AM
  #115
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Just finished welding up the UMI Performance SubFrame Connectors...
and now now I can mock up the exhaust....
new vid coming soon
Old 05-03-2019, 03:02 AM
  #116
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Stage 10 UMI SFC and Exhaust
Old 05-03-2019, 02:23 PM
  #117
GTA Sammy's Avatar
Car: 1989 T-Top GTA
I gotta take a minute to thank those that have chimed in either here, privately or on YouTube.
The help is greatly appreciated.
So are the kind words of encouragement.
Still lots to do, but there’s light at the end of the tunnel.
Chris
Old 07-22-2019, 11:22 PM
  #118
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Hey guys, a couple of members have PM’d me about the project... so I figured I should letcha know what’s going on.
First off the transfer case motor in my Sierra took a dump and caused a ton of subsequent problems...
Then the head gasket in the truck cracked and I ended up doing the top end (which was kinda alright to tell you the truth)
Then I wiped out my crotch rocket which left a terrible hole in my knee, the doc could put his whole index finger in it..... I think the brake pedal went through my leg. The hole and road rash was bad but the infection was way worse. Almost a month of IV antibiotics and I think I’ve finally beat it.
So I’ve been outta commission for the last month or so, but I’m starting to walk un aided and the MRI says that there’s no catastrophic damage.
I hope to be back in the garage soon to finish finish up this turbo project.
Keep your fingers crossed
Old 07-22-2019, 11:23 PM
  #119
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Old 07-22-2019, 11:25 PM
  #120
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Old 09-13-2019, 04:23 PM
  #121
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Alright!!!! I'm back.....
I’m moving around pretty good again after the motorcycle crash and got back into the garage to pull the fuel pump out.
I started to put the Aeromotive 340 in and started to look at the tiny wires coming out of it.
Now considering that I bought the Racetronix Hotwire Kit and the power wire is 10 gauge from the alternator to the very last connector before the pump....
Should I replace the last foot or so to a heavier wire?
The Hotwire Kit says that the pump can pull upto 20 amps under a heavy load, seems like the 2 wires coming out of the pump are a little under rated for that... looks like 18g....?
Old 09-15-2019, 11:47 PM
  #122
GTA Sammy's Avatar
Car: 1989 T-Top GTA
So after much contemplation, I decided to run heavier gauge wire to the pump from the end of the Hotwire Kit.
I removed the bulkhead plug and installed a grommet in its place.
Ran all three wires through the grommet, positive, negative and fuel level.
Soldered a 10G wire in on the positive and negative side then applied heat shrink as required.
i think it turned out pretty good...
Old 09-16-2019, 07:14 AM
  #123
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Not sure but i think wire length matters some in its ability to transmit amp load, so the short run of small gauge wire for pump harness may be ok. But you cant go wrong with larger wire
Old 09-22-2019, 02:36 PM
  #124
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
I use this chart often at work. Nothing wrong with going up to larger wire, but to answer the other question the length does indeed have a large effect on amp carrying capacity, as well as voltage and wire type. (Type is broken down elsewhere.) Most import part of higher current wiring is to be sure your fuse is rated to go up well before the wiring hits its limits thermally.
Hope your knee is doing better, I've been following this build for a good while and hope to do something similar in the future. Right now I have to finish my current set of upgrades but buying a house and moving this summer has put a hold on my stuff. Keep up the good work!
Old 12-27-2019, 06:51 AM
  #125
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Uploaded a new video last night
cut the fuel pump access door and removed the old pump...
I’ve already re-installed the Aeromotive pump but haven’t had the time to edit that video
Share, Like and Subscribe
its been slow, but it’s still moving along
there will be smoke this spring!!!!
Old 12-27-2019, 07:25 AM
  #126
GTA Sammy's Avatar
Car: 1989 T-Top GTA
I’m at 99 subscribers...
Big shoutout at whoever becomes the 100th!!!
Old 08-06-2020, 07:29 PM
  #127
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Got the fuel pump access door buttoned up...
Used threaded inserts and screws to fasten the door to the car...
Then onto turbo drainage...
Drilled a hole in the unused mechanical fuel pump plate And welded a pipe to it
to allow access for a oil return to the engine from the turbo.
Old 08-06-2020, 08:00 PM
  #128
Good update!
Glad to see this project still going! Did you consider the Mallory plate w/fitting though? I ran out of block off plates, and I didn't want to mess up the stock one, so I bought the Mallory piece...
- Rob
Old 08-07-2020, 12:01 AM
  #129
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks Rob,
I had seen those... or ones like them...
Trick piece!
Honestly, I had thought about it... but hate AN fittings and avoid them if possible...
I bought AN fittings and braided hose for my transmission lines and aux cooler (Can’t wait)
I’m not looking forward to installing the Dynamic EFI EBL P4 Flash
A little intimidated with repinning
Old 08-19-2020, 10:12 PM
  #130
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Soooooo, the downpipe is wrapped in fiberglass header wrap.
Was gonna install the starter, but figured now was a good time to run my transmission cooler lines....
I thought that I had done enough research and purchased all the AN fittings and braided line..., but I purchased the wrong fittings that go into the tranny case....
Old 08-19-2020, 10:14 PM
  #131
GTA Sammy's Avatar
Car: 1989 T-Top GTA
That’s the right part number for the AN Fittings that thread into the transmission case...
Old 08-19-2020, 10:16 PM
  #132
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Hope that helps someone down the road... I’m gonna have to move forward while I wait for new parts.
Luckily for me that there’s still LOTS to do
Old 08-21-2020, 06:59 AM
  #133
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Just posted part 13 of The GTA Trans Am Turbo Project.
The pump gets pulled out and new pump goes in.
Old 08-21-2020, 07:52 AM
  #134
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Looking good
Old 08-21-2020, 08:38 PM
  #135
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks Orr,
I can’t wait to get this project done....
Snows here the 1st week of November usually....
Old 08-27-2020, 10:17 PM
  #136
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Got my AN Transmission fitting adapters...
Mounted the tranny cooler in the Trans Am nose and started making lines...
Intercooler up front Power steering cooler next Then tranny cooler above
DynoDave43 (08-31-2020)
Old 09-07-2020, 11:38 AM
  #137
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Quick question.....
Do I NEED a kill switch if the battery is relocated to the back hatch???
Pondering my next steps...
Thanks in advance
Old 09-07-2020, 12:21 PM
  #138
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
If you are racing at a track, yes
BTW, I saw you at MPR on Saturday.
Get your car out!
GTA Sammy (09-07-2020)
Old 09-07-2020, 03:28 PM
  #139
Sammy, let me know if you’re in need of an FMIC. This is the larger 4” core version. Don’t need it anymore...
- Rob
Old 09-07-2020, 06:12 PM
  #140
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Get your car out!
Yup, that was me and the family....
Was trying to soak up some inspiration
Kinda bummed about putting a kill switch on a “street car”
Old 09-07-2020, 06:22 PM
  #141
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Any suggestions as far as kill switches go?
Old 09-08-2020, 12:19 AM
  #142
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Pretty sure this is what I have
https://www.summitracing.com/parts/mor-74101
If you are not racing it, you don't need it...
I put mine behind the rear license plate
Old 09-08-2020, 08:43 AM
  #143
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks G!!!
Take a closeup pic of it for me if/when you get a chance K?
Old 09-20-2020, 09:37 PM
  #144
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Old 09-20-2020, 10:12 PM
  #145
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Thanks!!!
Old 09-20-2020, 10:28 PM
  #146
DIGGLER's Avatar
my car had a kill switch like that one mounted in the bottom of the trunk facing the ground. then there was a rod connected to the lever and ran out one of the bottom license plate holes with a flat plate attached for the push off decal. worked good with zero holes drilled in the bumper.
GTA Sammy (09-21-2020)
Old 02-12-2021, 12:24 PM
  #147
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Hows this progressing
Old 02-12-2021, 01:10 PM
  #148
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Oh hey Orr...
things have been pretty slow ....
its -37*F here in the middle of the day....
and I’m a ICU Nurse so Covid has had me pretty busy these last few months....
Honestly, I don’t have far to go.
1) Battery relocation into the back. Run power.
2) Vacuum lines
3) MAF delete and MAP hookup
4) EBL repinning (which makes me nervous)
Old 02-13-2021, 07:38 AM
  #149
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 700R4 w ProBuilt
Axle/Gears: 9 bolt 4.11
Don't sweat the EBL repinning. I had mine (EBL Flash 2) sitting in the box most of last fall avoiding it doing everything else. And, I also had replaced my MAF harness with one from Painless so I figured I was really going to be on my own. Looked at RBob's instructions a couple of times, unplugged the 165 and started to swap pins thinking "that's all there is to it?" I think I emailed him once because there was one wire of a different colour but that was all. I had more trouble figuring out Racetronix's supposed plug and play harness...
Brian
Old 02-14-2021, 03:22 AM
  #150
GTA Sammy's Avatar
Car: 1989 T-Top GTA
That’s soooo good to know!!!
Thx Brian
Was -50*c or -58*F yesterday morning
Quick Reply: SBC SINGLE TURBO PROJECT
