305 switching tbi heads on 92 firebird
Old Dec 29, 2018 | 10:09 PM
Chevy_man_88's Avatar
Car: 1993GMC suburban1992Pontiacfirebird
Engine: 350, 305
Transmission: 4L60-E 4L60
I got a 305 tbi, can vortec heads from a 305 or 350 fit on my 92 firebird??
Old Dec 30, 2018 | 12:20 AM
NoEmissions84TA's Avatar
Re: 305 switching tbi heads on 92 firebird
Yes, both will physically bolt on, but the 350 heads will have a larger combustion chamber and therefore LOWER your compression ratio.
You will LOSE power.
Old Dec 30, 2018 | 08:33 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
he is correct and the 305tbi is already at something like 8.5.1 compression ratios. that's a dud. vortec heads are a great upgrade but then you have to change the intake manifold as well. a set of stock vortec heads are fairly affordable but by the time you buy a manifold as well you could almost buy a better set of heads made for the 305. 175-180cc heads are good for a 305. the set im looking at have a 56cc combustion chambers that will raise the compression ration closer to 9.5.1. the better heads and increase in compression will be power you can feel.
Old Dec 30, 2018 | 09:36 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
305 TBI cars are at 9:3 or 9:5 compression stock. Big upgrade to go with 305 Vortec heads and a carb Vortec intake can be bought cheap as well as an adapter to use your TBI with it. Still won't be a rocket id be looking for a 350 if I was wanting to make power.
Old Jan 1, 2019 | 06:14 PM
StunMan's Avatar
Car: '91 RS vert
Engine: mild TBI 305
Axle/Gears: 3.43 pos
Any head part numbers or truck/car years to look for these 305 Vortec heads? A true bolt on with the right manifold?
Old Jan 1, 2019 | 07:37 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
L30 heads are 12558059 I believe.
1996 - 2000? I'm not certain what year production ended.
FF32
Jun 2, 2009 09:49 AM
Florida Bird
Apr 11, 2009 07:16 PM
92green3RdGen
May 31, 2007 12:28 PM
myinvestedagony
Oct 2, 2002 01:07 PM
