switching heads and intake on 305 tbi
hey i was just wondering how hard it would be to switch heads and the intake on a 305 tbi? they are vortech style heads and the vortech tbi intake i have all the hardware but not all the tools could i just do this in my garage? some info would be great!
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: switching heads and intake on 305 tbi
Its not too bad, and is easily done in a garage, but without the right tools, itll be difficult. The heads especially require attention as well as a good torque wrench and other tools to make sure the gasket surface is clean and there willl a good seal. Basically you have to get the gasket surface spotlessly clean w/o removing any material from the deck surface, which requires a gasket scraper and LOTS of blades. In addition, youll need teh usual inch and ft/lb torque wrenches, socket set, extensions, u-joints complete torx bit set (good ones, not the cheap stuff) screw drivers, and lots of other stuff I forgot to mention.
