wasregates
Old Feb 21, 2019 | 02:59 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
wasregates
im wondering is two small wastegates better than one large one on a single turbo setup
Old Feb 25, 2019 | 08:50 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: wasregates
Its preference really. I run 2 - 38mm tials on mine but I have to since i run a TRUE twin scroll.
Pro's and cons to both. You could get a lot better control out of two gates especially if you can only fit one large one in a terrible place. Then there is also if say a gate sticks or fails, at least the other could save the motor. The advantage of one is definitely piping and hoses. Less to worry about
Either will get the job done.
Jay
Old Apr 4, 2019 | 09:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: wasregates
Yeah it depends. Like above if its a twin scroll divided setup run 2. If a single merge, running one large one makes a simpler setup. One vacuum line to supply, one valve to worry about. Less chance of one failing or something odd happening
but one large is physically larger than two small lol if room is an issue may package twin gates easier. Two smalls can be cheaper than a large single depending what you get
most setups i would try a single for simplicity
if its a giant single big power small tire car then two large may be necessary to control it and pass the flow. 1800-2000 hp stuff lol twin 50’s or more may be necessary
Old Apr 5, 2019 | 02:15 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: wasregates
im gonna go with the single large one . i remebered i had one over at my buddies house .im gonna run a 7875 on a lm7 5.3 . im only planning on making 5-600 whp .
